11-12-2018, 05:36 PM | #1 |
Rep 30
Resonator & Muffler Delete
Interested in doing a muffler and res delete on my 435xi. I also have the MPE installed and wondering what kind of drone i will experience if doing these two deletes and if it will really be that bad. Or if doing one is better than the other, looking for some real sound and pops!
11-12-2018, 07:01 PM | #3 |
Rep 470
IIRC the resonator helps reduce raspiness of the exhaust, while the muffler helps reduce overall loudness.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
Dr_Glob1.50 |
11-12-2018, 08:55 PM | #4 |
Rep 1,934
Lol muffler delete will mean you remove the MPE. The resonator will only add drone. Don't remove that. With the MPE, adding a catless or HFC will get you the pops you want with no drone.
Dr_Glob1.50 |
11-12-2018, 09:08 PM | #5 |
Rep 30
Thanks for the advice, any reccomendations on brands for HFC im assuming your talking about a downpipe?
11-12-2018, 09:23 PM | #6 | |
Rep 1,934
11-12-2018, 09:27 PM | #7 | ||
Rep 30
11-12-2018, 09:30 PM | #8 | |||
Rep 1,934
A straight pipe would be any section of pipe that is straight-through with no obstructions like a resonator or muffler baffling. In this case the catless downpipe is essentially a straightpipe.
Dr_Glob1.50 |
11-12-2018, 09:39 PM | #9 | ||||
Rep 30
11-12-2018, 09:50 PM | #10 |
Rep 1,934
Not sure as I've always avoided the dealer and do a lot of diy. You'd have to ask your service manager.
Plus, if you have to deal with state inspections then there's also that, as well.
Dr_Glob1.50 Gospeedracer27.00 |
11-12-2018, 09:56 PM | #11 | |
Rep 30
11-14-2018, 06:09 PM | #12 |
Rep 190,633
Not a big fan of this setup. You are better off getting a proper exhaust system instead
Dr_Glob1.50 |
11-14-2018, 06:10 PM | #13 |
Rep 30
11-14-2018, 06:12 PM | #14 |
Rep 190,633
Since you already have MPE and you want more sound i recommend an aggressive setup like catless downpipe + REMUS axle back (stock midpipe)
Dr_Glob1.50 |
11-15-2018, 07:20 AM | #15 |
Rep 14
I have a resonator delete and a removable muffler delete that I never put on because it made the drone unbearable. I currently run a vrsf catless and resonator delete and it sounds perfect.
11-15-2018, 12:36 PM | #16 |
Rep 937
I removed my resonator (have MPE axle back), no drone.
Hi
11-15-2018, 03:53 PM | #17 |
Rep 156
I have a catless downpipe with no muffler and it drones incredibly bad. It rattles the plastic in the cabin. It sounds incredible when under high load though
11-15-2018, 05:09 PM | #18 |
Rep 30
11-15-2018, 05:10 PM | #19 | |
Rep 30
11-15-2018, 07:09 PM | #21 | |
Rep 30
