01-24-2022, 07:09 AM | #89 |
Rep 59
Yeshttps://f30.bimmerpost.com/forums/attachment.php?attachmentid=2796108&stc=1&d=164302 9757
01-24-2022, 07:11 AM | #90 |
Rep 40,771
Do you have Coding error during both VO Coding and FDL Coding?
01-24-2022, 07:20 AM | #91 | |
Rep 59
This error comes then i try to read the KOMBI CAFD. I haven't tried to code VO OR FDL only then i connect to the NBT and i connect directly with IP adress to the NBT unit and with the VIN then i'm trying to acess the KOMBI, my guess is there is some bad communication between the KOMBI and the NBT unit, since i cant reset the error code i mean. |
01-24-2022, 07:28 AM | #92 | |
Rep 40,771
01-24-2022, 07:40 AM | #93 |
Rep 59
01-24-2022, 05:26 PM | #94 |
Rep 59
This is what i got, then i tried to hit Code.
https://f30.bimmerpost.com/forums/at...1&d=1643066678 https://f30.bimmerpost.com/forums/at...1&d=1643066678 https://f30.bimmerpost.com/forums/at...1&d=1643066678 https://f30.bimmerpost.com/forums/at...1&d=1643066678 https://f30.bimmerpost.com/forums/at...1&d=1643066678 |
01-24-2022, 05:46 PM | #95 |
Rep 40,771
So you retrofitted NBT, not KOMBI, and you can code your retrofitted NBT, but not your factory fitted KOMBI?
01-24-2022, 05:56 PM | #96 |
Rep 59
01-24-2022, 05:58 PM | #97 |
Rep 40,771
No idea. Makes no sense. Did you modify FA for NBT and if so, in what way?
01-24-2022, 06:04 PM | #98 | |
Rep 59
So for a few weeks ago i got this Tire Pressure error, i need to get rid of it as i have this 2 year control of my car this month. |
01-24-2022, 06:06 PM | #99 | |
Rep 40,771
01-24-2022, 06:10 PM | #101 |
Rep 40,771
Well, I would try Coding Kombi with original FA, and see if that works.
If that fails, I'd flash Kombi.
01-25-2022, 04:39 AM | #102 |
Rep 59
Hmm, had to connect via gateway, this way i could code the Kombi, i guess it has something to do with the retrofit of the NBT, i guess the NBT is now the gateway to code the Kombi.
01-25-2022, 09:13 AM | #103 |
Rep 40,771
Ok, your Profile shown "Drives: Bmw F30" but I see above you wrote this is a 2010 F10. This is to be expected. In a PRE LCI F10, it has ZGW1 with MOST and ZGW is MOST gateway whereas in an LCI car with NBT, ZGW2 has no MOST so MOST gateway in car is NBT, all data to MOST is forwarded by ZGW to NBT on ETH and NBT takes care of this data to reach KOMBI via MOST.
08-05-2022, 06:11 AM | #104 |
Rep 12
Hi shawnsheridan,
sorry to disturb you, but I have a question: I retrofitted the 6wb cluster in my F31, BY 07/2017. I've changed my VO from 6WA to 6WB. Everything runs smooth until I've tried to code the kombi. "Transaction Report: Action: Encode Cancellation! Error in SVT. [C398] Duplicate control unit entry for diagnostic address 96. [165]" I've tried to use different i-levels with "cafd zu swe...", but it is always the same error message. Can you help me please? I would really appreciate it!! Thanks a lot in advance!!! |
08-05-2022, 09:41 AM | #105 | |
Rep 40,771
08-05-2022, 11:09 AM | #106 |
Rep 12
thank you very much for your reply and help!
To shorten it a bit: I made it. I guess my mistake was that I've selected the newest cafd. I've now used an old(er) i-level from 2017 for cafd (DKombi) instead of one of the newer ones (2020+) and it was coding flawlessly. Thanks again for your help! ...but one more question please: Do you know if there is no "M-Performance logo and start up/boot screen" for the 6WB cluster anymore? If I code "m-performance" (e-sys and i also tried it with bimmercode) it shows "M550d"?! With my 6WA cluster, I was able to code the m-performance logo/start up screen (HUD). Last edited by ibizastyler; 08-05-2022 at 11:16 AM.. |
08-05-2022, 01:13 PM | #107 | |
Rep 40,771
09-22-2022, 06:10 PM | #108 |
Rep 6
bimmercode 999999 red dot problem
hi anyone can help me resolve issues on my cluster , i tried injecting cafd but still the same .original mileage still registered in cluster
09-22-2022, 06:12 PM | #109 |
Rep 40,771
Kombi was retrofitted? New or used Kombi?
09-22-2022, 06:21 PM | #110 |
Rep 6
its original kombi of the car. i got that error when i was coding with bimmercode app. after coding digital seed on cluster right after it rebooted its 999999
