04-06-2019, 01:47 AM | #45 |
Rep 5,101
My brother in law used to fly the 737 specifically the 800 series and says it was an absolute bugger to land due to its low landing gear height and increased length.
It’s an ageing airframe design that actually sits very low once on the tarmac, it was never a problem with the original engines but the new high bypass engines are bigger and sit lower hence the need on the MAX to have them sit further forward and slightly higher which then contributes to the aircraft wanting to pull its nose up. Boeing have therefore quietly ‘fixed’ the issue with software. When the sensors go rogue the plane goes into anti stall and pushes the nose down. |
04-06-2019, 02:05 AM | #46 | |
Rep 5,101
04-06-2019, 02:13 AM | #47 | |
Rep 3,285
Unstable aircraft design is what gives things like Eurofighter amazing maneuverability, pretty much all modern jets like the F22 would fall out of the sky like a rock without software and hydraulics. Its not really an issue for fighters as if the worst happens the pilots can eject, and in most cases the military would probably prefer a wreck on the ground than an intact plane which can be salvaged by the closest farmer. Not sure you would want the same design philosophy in a commercial jet designed to carry hundreds and civilian pilots, and planes that will be serviced/maintained at minimal cost for decades though. Boeing has messed up big time, but no amount of guilt is going to make a ounce of difference to the people who died. I cannot imagine what the pilots were thinking leading up to the crash, must have been literally staring death in the face!! |
Watsey6406.50 |
04-06-2019, 02:17 AM | #48 | ||
Rep 8,780
Where the 737 beat the 757 was being low enough to operate from small airfields with manually propelled stairs - the sort of places that proliferate in the US and generally outside of Europe. This meant that the 737 could compete to replace the 717/MD-80/90/DC-9 (all generations of the same airframe) and other smaller planes that the regional airlines have in huge numbers, and need to replace. The 757 couldn't do that. Then fit bigger new engines on the 737 MAX to also remain competitive against the A320 NEOs. Big new engines further forward and with a shape to generate more lift in that forwards position, as described above. Too many upgrades to a 50 year old airframe imho, a clean sheet was needed - but the airline industry is too cut throat to pay for that, which is driven by the majority of us picking the flight that is £10 cheaper when given two options. Take a look at a picture of a 737-100 with low bypass engines and it's amazing how tiny they look. You can go back to being the scouse Howard Hughes now NB. When I've flown out on, say, a B787, and flown home on a A330 I've always considered those two flights as being on two different aircraft types. After reading this thread, I'm not sure which one I am allowed to claim I was on? Longest time on board?
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
Broncho2311.00 |
04-06-2019, 02:26 AM | #49 | |||
Rep 5,101
MashinBenzin8454.50 |
04-06-2019, 02:59 AM | #50 | ||||
Rep 8,780
04-06-2019, 03:08 AM | #51 | |||||
Rep 5,101
04-06-2019, 03:10 AM | #52 |
Rep 25,112
Someone should be going to prison for a very very long time with what's happened on the 737 Max release. Shocking safety.
Would I fly on one, probably once they are released again, I guess when you book you don't know plane it is do you?
My car made front page of Bimmerpost
04-06-2019, 03:13 AM | #53 | ||
Rep 2,217
The other week he told me he had drunk 5 halves of lager and had a hangover. I had to explain that given the presence of froth, and taking into account precipitation, his 'claim' was unsubstantiated and he'd only actually had 4 halves of lager and should be executed for his 'claim' and never 'claim' anything again. Damn him and his 'claims'. |
04-06-2019, 03:18 AM | #54 |
Rep 19,982
Loving the airplane geekery here. I'd just discussed this briefly with my neighbour, who's a commercial pilot and instructor, and info in this thread has helped me understand the back story to make sense of what he was trying to tell me about the larger and heavier engines.
The problem with software is that it's never quite right and the quickest way to develop it is beta testing. That's fine for an app, but it's not quite the same if it's safety system in a plane. By the way, I flew at least 30 times last year, do I get a prize?
04-06-2019, 03:22 AM | #55 | |
Rep 25,112
Edit this will look out of context now but it's not my fault, Bimmerpost App (servers maintained by Boeing Beta testers??) kept it in Draft for all of 4 minutes then Bronchos holiday schedule discussion took off then took a nose dive. #seewhatididthere
MashinBenzin8454.50 Broncho2311.00 |
04-06-2019, 03:26 AM | #56 | |
Rep 8,780
You're right, not much choice when you book apart from choosing a Boeing only or airbus only airline. Even when you know the usual plane, it may be subbed on the day you are flying.
04-06-2019, 03:27 AM | #57 | |
Rep 8,636
Alternatively SeatGuru.com is a great place to check. We’re on a 737 in 4 weeks, but it’s an 800, phew! Not that the max would be flying by then nor do Thomson have any on their fleet. |
JustChris17487.50 |
04-06-2019, 03:45 AM | #58 | |||
Rep 5,101
04-06-2019, 05:12 AM | #59 | ||
Rep 8,493
04-06-2019, 05:58 AM | #60 |
Rep 93
Just so you know Thomson called TUI now and they do have MAXs and there is at least 5 of them sat on the taxiway near the end of one of Manchester’s runway!
04-06-2019, 06:14 AM | #61 |
Rep 93
I’ve read through the thread and thought I’d stick my say in especially towards the safety in the most part in the aviation industry. I do not fly airbus or Boeing so not biased towards either but do believe the fundamental issue comes into cost as due to the southwest changing the American airline industry followed by the likes of Ryanair following in Europe that people do expect to pay not very much to fly on aircraft in today’s world and where do we expect say £50 (notional amount) per flight ticket to get you and the costs it includes for fuel, pilots, cabin crew, ground handlers, tax etc I could go on. So when looking at the industry it becomes cheaper to redesign older models as they keep commonalities for pilot training etc than design and certify a new design. In the case of the B737 it may now be a step too far to keep up with airbus. The 737 is fundamentally a much older design as the airbus was produced in a much later era with bypass engines and the landing gear design for the clearance to accommodate such engines.
Now this is the second case for Boeing with its last 2 new aircraft after B787 and it’s battery issues. Now when the Max does become airworthy again I’m sure it will be as safe as any other design as the US government are scrutifying the FAA for the original certification so everything will need to checked over and over again but this will no doubt take much longer than Boeing and the airlines want |
04-06-2019, 06:40 AM | #62 | |
Rep 8,636
TuiFly have Max’s but we aren’t going with them, their site shows they only have 4 unless they have just had delivery of others. https://www.tuifly.be/en/our-fleet https://www.tui.co.uk/flight/flying-with-us/our-fleet Last edited by SkyJawa; 04-06-2019 at 06:54 AM.. |
04-06-2019, 06:58 AM | #63 | |
Rep 93
As an aside note Ryanair have a massive order for Max’s to be delivered in the future and the other airline you could commonly see with Max is Norwegian. |
04-06-2019, 07:04 AM | #64 | ||
Rep 19,982
04-06-2019, 07:07 AM | #65 |
Rep 8,636
I’m aware of the rebranding from ages ago hence why I said now called Tui Airways. Yes you are right seems their website is out of date, but it’s irrelevant to our flight anyway as said.
Also despite the rebranding they still carry the TOM flight code. |
