04-23-2019, 11:39 AM | #45 | ||
Rep 762
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-23-2019, 02:32 PM | #47 |
Rep 500
Drives: BMW 330e F30 M-sport
Will be interesting to follow this, keep us posted
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
04-23-2019, 03:24 PM | #48 |
Rep 106
Why are you not using stock plugs? Why has no one recommended this yet?
A Stage 1 tune should run stock plugs. Every thread I see on here people with issues such as your self, are running different spark plugs. Go with OEM and it could fix your issues. I know you are not using MHD, but MHD recommends stock spark plugs. Changing spark plugs and especially the gap, will fuck with your timing. |
harkes1077.00 |
04-23-2019, 03:34 PM | #49 | |
Rep 1,170
And started the car and it was perfect idling for about 20 min with no problems Once I turned it off and turned it back on small misfires started to occur again and sure thing check engine light again so that didn't make a difference The car starts up perfectly fine Some times it idles great no check engine light nothing and can idle no problem but once I turn it off and turn it back or I put it on gear that's when I start to feel misfires And I get a check engine light misfires Cylinder 1 and 6and another code for p0300
bmw m2
04-23-2019, 04:45 PM | #50 |
Rep 106
Gotcha!
Are the stock plugs it in it now that it is at the dealer? If not, let them know. You could have bad injectors, egr system issues, camshaft position sensor or a bad ecu(god damn I hope not!). Keep us posted please! |
04-23-2019, 04:48 PM | #51 | |
Rep 1,170
I thought that was going to solve the problem When I first cranked her up It idled PERFECTLY fine I thought the problem had gone away And no it didn't lol I was so bummed And man I hope is nothing too deep I'm out of warranty smh
bmw m2
04-23-2019, 07:37 PM | #52 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
Good luck OP. Subbed.
04-23-2019, 08:13 PM | #53 |
Rep 832
Drives: 2019 G01 X3
Stock plugs for the N55 are not the NGK 97506. I would try the OEM Bosch plugs at stock gap...
04-23-2019, 10:03 PM | #54 |
Rep 106
04-24-2019, 08:42 AM | #55 |
Rep 832
Drives: 2019 G01 X3
Maybe you misread the thread (or maybe I’m just misunderstanding him), but he says he installed stock plugs, when he actually installed NGK 97506 plugs (per the first page). Those are OEM N20 plugs. I am suggesting he try the stock N55 Bosch plugs.
04-24-2019, 10:30 AM | #57 |
Rep 1,170
I did try out the ngk spark plugs on the stage 1 map car didn't like it so I immediately installed stock Bosch plugs
The OEM Bosch plugs from the bmw dealer
bmw m2
04-24-2019, 11:06 AM | #58 |
Rep 1,170
I'm just hoping that the last map didn't mes up my car
As soon as I uploaded that second map pro tunning freaks sent me It was a wrap the car just did not like it Nothing helped after that I went back to stock That didn't work My car was running great before bm3 I can tell yaw that much
bmw m2
stroker1562.50 |
04-24-2019, 11:33 AM | #59 |
Cheapskate
4447
Rep 4,993
I don't know why you're so deadset on checking and rechecking what you've already done. P0300 could be anything.
Bad MAF Bad Vacuum leak Failed/leaking DV Bad O2 sensor Try actually troubleshooting your car before just saying everything's new and running more and more logs. How does it run with the MAF disconnected? Have you tried a pressure/smoke test? |
FSociety3812.50 |
04-24-2019, 11:43 AM | #60 | |
Rep 1,170
I stop trying to even drive the car What I basically did was just put the car back to stock and let my friend at the dealer diagnose it From there on I did small diagnose Like change injectors Change coil packs Change spArk plugs on the cylinders it was actually detecting misfires I'm not no mechanic so I just stopped there and let my friend handle it from there on Is at the dealer now getting looked at
bmw m2
stroker1562.50 |
04-24-2019, 11:55 AM | #62 | |
@_sunbish
282
Rep 611
That is not diagnosing, that is part replacing. Unless you fried the DME or the computer (not sure if they are one in the same as I am new to these cars), then it’s not something that BM3 caused. Obviously if nothing changed between changing all those maps and going back to the stock map, then it isn’t software related but hardware related. I’m sure it isn’t anything major and you’ll have your car back on the road in great running condition soon. |
kern4174446.50 |
04-24-2019, 02:32 PM | #63 | |
Cheapskate
4447
Rep 4,993
04-24-2019, 02:42 PM | #64 | ||
Rep 1,170
They been actually helpful giving me suggestions and they still told me to get back at them when I figure out the problem but it was weird tho cuz once I installed the second map I wasn't even able to do a log when my car just did not like it lol
bmw m2
04-25-2019, 04:43 AM | #66 |
Rep 373
I have run BM3 for one and half years 20000 miles later car is Perfect so whats your point?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
