05-22-2021, 01:57 PM | #1 |
Rep 87
Drives: 2014 335i Xdrive
[IMG]https://youtube.com/shorts/U9vDFsk9H08?feature=share[/IMG]
I just changed my sparks and coils with bosch products, but now the car shakes and has hiccups that i hear through the exhaust. I torqued them down to 17ftp (sparks) gapped at oem spec. What coulda be the issue and what could I be doing wrong. I tried to put in the old sparks and plugs but having the same issue. There are no codes being thrown. RPM jump a little on start I have also went back to stock tune but am still having the same issue. Some advice and help would be appreciated See the video attached! 2014 335i n55 ewg Catless dp Intake Stage 1 |
05-22-2021, 02:43 PM | #3 |
Rep 87
05-22-2021, 03:17 PM | #4 |
Rep 1,572
That "sounds" like an ignition coil not being fully seated or it's connector not being fully seated and the retainer fully closed. Dialectic grease is ok, but only in very small amounts. Too much and the coil may tend to slide up on the plug.
05-22-2021, 03:27 PM | #5 |
1296
Rep 3,533
it's an ignition problem as started above. coil or plug issue
05-22-2021, 03:55 PM | #6 |
Rep 87
Can someone send a link to the grease and how/where to apply it
05-22-2021, 04:21 PM | #7 | |
1296
Rep 3,533
I mean.. yeah
05-22-2021, 04:32 PM | #8 |
Rep 461
I've never used grease. With the ignition coils having a rubber seal shouldn't be necessary.
Thought that might have been the cause of op's issues if he had. |
05-22-2021, 04:36 PM | #9 |
Rep 87
05-23-2021, 04:00 PM | #10 |
Rep 87
Still no luck.
Im gonna try and send back the sparks and coils to fcp euro and get oem BMW ones |
05-23-2021, 08:30 PM | #11 |
Rep 10,351
If you had a scanner you would know which cylinder is causing the issue.
"Drive more, worry less. "
05-23-2021, 09:09 PM | #12 |
Rep 87
05-25-2021, 06:18 AM | #13 | |
Rep 10,351
05-25-2021, 08:43 AM | #14 |
Rep 562
Drives: 2017 BMW 330i xDrive
I'm surprised the car isn't throwing codes if it's misfiring like that...but nothing you can do about that if it isn't.
Back to the beginning though, I see where you put the original plugs back in but unless you missed it, or had a typo, I don't see that you tried putting the old coils back on, too. Could be one of your new coils is bad.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
Aceway454.50 |
05-25-2021, 12:08 PM | #15 | |
Rep 410
05-25-2021, 04:45 PM | #16 |
Rep 461
That's a fresh take.
Problem with a fuel injector so I went ahead and installed PI. |
n55david1295.50 Pussiwillow521.00 |
05-25-2021, 05:35 PM | #17 |
Rep 87
Interesting, Im not sure since I wasn't have fuel injector issues before.
My new coils are on the way , ill keep you updated |
05-25-2021, 05:40 PM | #18 | |
Rep 87
Ill see how i goes once I get my new coils |
05-25-2021, 07:48 PM | #20 |
Rep 7
As a technician, I had a similar problem, but on a different car. It was a 2008 Infiniti G35. These cars were notorious in accidentally mixing up ignition coil wires. Check to see if you accidentally mixed up 2 ignition wires. (i.e ignition wire for cylinder 1 to cylinder 2.) If you swapped back to your original coils and plugs and the problem is still there, but you never had a problem from before the coil & plug install, then there is a big chance that it was a human error and not the car or the parts.
05-25-2021, 08:56 PM | #21 | |
1296
Rep 3,533
Pussiwillow521.00 |
05-25-2021, 11:17 PM | #22 | |
Rep 87
