BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Winter Tire choice for 440I Xdrive Coupe
Studio RSR
      10-19-2020, 03:03 PM   #23
Alvin Mpower
Drives: 2016 M4 ZCP
Originally Posted by M Smurf View Post
depends on tire size
same set up, 225/40r19 font 255/35r19 back, he says i need 5x112 bolt, is that the same size?
      10-19-2020, 03:13 PM   #24
Psi5
Psi5's Avatar
Drives: 2020 BMW F32 440i
Originally Posted by J555 View Post
Well, they scored as 19th out of 20 in the current, possibly the most respected european, comparison test of UHP winter tires: https://www.tyrereviews.co.uk/Articl...-Tyre-Test.htm .
My experience is similar, if not worse. Just saying.
Also depends on size and whether you want runflats. If you have 18's, Sottozeros are pretty much your only option if want runflats unless you want to drop $300+ on Nokians. Here in Northern Virginia, it does not snow enough to justify that and for our Dec-Mar "snow" season, the Pirellis have been perfectly fine.
Garage:
2020 F32 440i 6MT
2018 Mazda 3 6MT
2013 Mazda 3 6MT
2008 Honda Oddyssey
J555568.50
      10-19-2020, 04:06 PM   #25
J555
Drives: F31 LCI 340iX
Interesting. Very different here, the first shop I have checked has plenty of choices for 225/45/18 runflats - TS860P, TS850P, TS830P, UG Performance+, UG Performance G1, PA4, WinterSport 5, LM001, Sottozero 3/210 II/240 II, W320B, WR A4.
Nokians are very specific tires. An extremely popular brand in my country, but for very little reason
      10-19-2020, 05:34 PM   #26
Bongoxxx
Drives: 2018 340 XDrive
Originally Posted by horrizenashisland View Post
Hey guys, I just find a set of new Rim and Tire from someone of facebook marketplace, he is selling his brand new m340i 19in rims and tires, less than 100 miles on them, will this fit my 440i? The rim looks exactly the same as my current rims.
If it’s a G20 m340, they have a different bolt pattern than your 440.
Your F32 would be 5x120
The G20 is 5x112
The rims won’t fit.
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey
Previous: 2016 328 xDrive Alpine White
      10-19-2020, 09:39 PM   #27
FIDDYgg
Drives: 2018 340i X-Drive
I did a lot of research last year before selecting winters for my 340i x-drive, I went with Continental VikingContact 7's mounted on 18's in a square setup and could not be happier with them. Quiet, comfortable and excellent traction in all of our gnarly Alberta, Canada winter conditions.
2018 340i X-Drive | M-Sport | MPPSK | Dinan Intake
      11-10-2020, 08:55 PM   #28
Alvin Mpower
Drives: 2016 M4 ZCP
So I went for the continental extremecontact DWS06 cause I don't want to go through all the stuff with reprogramming with different size tires and didn't want another set of wheels. Anyone know if I use the same PSI for tire pressure as the original one since the tire are the same size, the only difference is it's not run flat anymore, not sure if that affects anything but the TPMS on my car is reading wrong tire pressure after I put 35 front and 38 back, its reading 36 and 40.
      11-11-2020, 08:04 PM   #29
dkreidel
dkreidel's Avatar
Drives: a lot of BMW's
In three words: Nokian, Nokian , Nokian
Hakka R3's, WR G4 or WR G4 SUV depending upon the size you select, and with all Nokians...availability.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option
