10-13-2020, 10:40 AM | #1 |
Rep 102
OBDii reader
My Autel ODB2 reader doesn't work for my car now for resetting Pxxxx codes.
I am planning to get another a ODB2 reader and/or a combo kit that can function below. -Resetting Pxxxx codes -Disable fog light detections -Program close side mirror after remote close door -Upgrade steering wheel to sports one -Upgrade onboard digital cluster display 6WB in the future (this one is hard..) Thanks!
F30 335i xdrive
10-17-2020, 10:37 PM | #3 |
Rep 102
Bimmercode is like $32 & adaptor is like $30
Bimmertool app looks like its only on Android devices. How much it costs?
F30 335i xdrive
10-19-2020, 02:22 AM | #7 |
2JZ-GTE
2959
Rep 3,948
Esys for coding I use.
10-19-2020, 04:35 AM | #8 | |
Rep 909
Bimmercode= Coding the car Bimmerlink = Error messages, battery registration, gauges etc. Last edited by davidr3; 10-19-2020 at 03:44 PM.. |
10-19-2020, 07:11 PM | #9 | |
Rep 102
Esys believe is a PC with ODB2 cable. Read about it before. Got to the point you need to get a map/code for special car from a torrent. I dropped this one.
F30 335i xdrive
10-19-2020, 07:32 PM | #10 |
Rep 909
10-21-2020, 03:06 PM | #11 |
Rep 102
Can Bimmerlink replace ODBii reader? and/or monitor cylinder pressure?(I just replaced my spark plugs, will need to see if the combusting correctly)
F30 335i xdrive
10-21-2020, 04:12 PM | #12 |
Rep 909
You'll still need an OBD 2 tool so that your phone can connect to the car. I'm not sure about monitoring cylinder pressure but I can tell you that it gives you access to practically every measurable variable on the car, so if there's a sensor of sorts I'm sure it's possible, but i'm not 100%
