BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > bm3 stage2
Studio RSR
      04-10-2021, 03:22 AM   #1
haibebei
Drives: f30 320im M sport
bm3 stage2
hello
I finally flashed to bm3 stage 2 91 OCT with HFC DP. The throttle response is much quicker than stage 1 without hfc dp.
but the log looks not very good. maybe the oil quality is too poor here in Shanghai, China.
here's the log:
https://www.bootmod3.net/log?id=6071...729b55d97afe97
      04-10-2021, 06:37 AM   #2
Freddie_Rome
Freddie_Rome's Avatar
Drives: Bmw F20 120i
WOT at low rpm isn't a good idea. In fact you got a knock at 2'000 rpm, pedal to the metal and then a lot of timing correction. I suggest you to flash ACN91 map, that is specific for low quality 91oct fuel and use a booster octane.
      04-10-2021, 09:55 AM   #3
tpoddar
Drives: BMW 320i B48
Originally Posted by haibebei View Post
hello
here's the log:
You definitely need to get better fuel or use the ACN91 map. You're getting knock and excessive timing correction. If you continue to use this map you will surely damage your engine, I would suggest reverting to the ACN91 map and then log again.
      04-10-2021, 08:59 PM   #4
haibebei
thanks for reminding. Maybe I should put 95 RON gas for 91 OCT map.
I used to put 95 RON for stage 1 91 OCT which is fine.
      04-11-2021, 08:03 AM   #5
haibebei
I flashed to ACN map today. The log looks better but it's still not perfect.
Please check it again. thx.
here's the logs:
https://www.bootmod3.net/log?id=6072...90c65de5b75391
https://www.bootmod3.net/log?id=6072...729b74dec8238e
      04-11-2021, 01:43 PM   #6
ScottSmith
Drives: BMW E46 N20
The 91 octane rating is for the US system; so yes you should be using 95 RON to be equivalent to 91 (RON+MON)/2.
http://www.pencilgeek.org/2009/05/oc...nversions.html
      04-13-2021, 02:36 PM   #7
Freddie_Rome
here's the logs:
It seems a bit better but you should contact bootmod3 support for analysis.
      04-21-2021, 10:59 PM   #8
haibebei
yes. I already sent them the logs and they updated a CHN91 map for me as the gas quality here is so poor.
And they also asked me to log the stock tune. Here are the results from stock tune. I'm very surprised to see that. The only mod for my is a hf air filter and hfc 200 cel downpipe.
https://www.bootmod3.net/log?id=6080...729b3164a7b273
https://www.bootmod3.net/log?id=6080...0b433b1bc1d0f1
https://www.bootmod3.net/log?id=6080...729b30e7c1fec0
      04-22-2021, 11:59 AM   #9
Freddie_Rome
So, with stock ecu also did you get dirty logs? You should try booster octane
      05-01-2021, 09:04 AM   #10
haibebei
I change to RON98 fuel now. The log now looks much better on CHN 91 map which is made by PTF.
But I'm not sure why there is always boost pressure deviation between target and throttle.
https://www.bootmod3.net/log?id=608d...90c673b723db3e
      05-24-2021, 03:34 PM   #11
wenlipai
El Salvador
Drives: BMW 428i coupe
hi how long did ptf reply you with a new or modify map? as I'm having trouble similar as you, so far 2 days no reply from them.
