03-22-2016, 08:44 AM | #1 |
Rep 1,240
Drives: 2016 BMW 340i
2016 340i Water Pump Failure
6 months in and 4,800 miles on the odo, issues with the new B58 engine are starting to show.
Drove back home from work yesterday, my usual 30 mile commute, and noticed drops of blue liquid on the driveway and garage. Look underneath the car and coolant was dripping down quite rapidly. Luckily, I had a half gallon jug of BMW coolant from a previous purchase in the garage, with which I filled up the coolant bottle and drove off to the dealership (12 miles away) to drop the car off without an appointment. Halfway to the dealership, the 'low coolant' warning came on but the temperature stayed normal until I got there. Here's a video after I parked in the garage yesterday: https://www.youtube.com/watch?v=lpAayQaefxg Received a call from my SA a few minutes back and he informed me that they diagnosed the issue to bad water pump and a replacement would have to come from Germany, which would be 1 - 2 weeks depending on customs clearance. They were out of loaners when I got there but fortunately, although I didn't have an appointment, my SA and the Service Manager got me into a brand new 2016 328i loaner that they decided to pull off the lot for me. The service manager also instructed the SA to assign a shop foreman to my car and make sure they limit the mileage on the test drive (see here for backstory). |
03-22-2016, 09:06 AM | #3 |
Rep 265
Drives: 340i M Sport
Sucks to be you!
Sorry, trying to make light of a shitty situation.
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP |
03-22-2016, 09:21 AM | #4 |
Rep 26
Sorry to hear that. I hope it isn't a major issue with everyones 340's. However I don't get the first year jitters from some people. There are countless problem threads from people who have the old engine. So what's the difference?
03-22-2016, 09:31 AM | #6 | |
Rep 2,639
Basically, they reverted to the mechanical water pump instead of electrical. Also a couple other major/minor changes. Most people usually hold off a year or two after a new engine is released due to problems, and usually by the second year or third, everything is usually fixed. |
03-22-2016, 10:43 AM | #8 | |
Rep 26
03-22-2016, 10:45 AM | #9 | ||
Rep 2,082
Better the devil you know than the devil you don't know
03-22-2016, 10:48 AM | #10 | |
Rep 1,240
I bought the 340i knowing fully well that it is a 1st year motor and that I will be taking a risk with it, just like so many others have done with their 340is. The dealership is taking care of it and I'm not without a car. So, we just have to see how soon they can fix it and hopefully it is not a widespread issue on the B58 motors. |
03-22-2016, 12:56 PM | #12 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Any belt driven water pump has seals which are prone to failure, it's not like this motor uses some new leading edge water pump design that's never used in another vehicle before... I highly doubt this has something to do with the "new platform" lol
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
03-22-2016, 01:30 PM | #13 |
Rep 1,240
03-22-2016, 02:34 PM | #14 |
Rep 16,054
The basic design wouldn't be new, the part itself might be. Designers prefer to use existing off the shelf components, but sometimes they have to start from scratch. That's usually the case with a new block. If you had the part number you could search to see if it's used in older models. Since the dealership doesn't have them in stock that could mean it's a new part, or it could mean it's a old one that doesn't fail so often that they'd bother to stock it.
03-22-2016, 05:57 PM | #15 |
2JZ-GTE
3005
Rep 3,986
where was your 340 built? Germany or South Africa
03-22-2016, 08:03 PM | #16 |
Too much is never enough
655
Rep 3,079
This is just a tad overly dramatic. Sorry for your luck, but your sample of one isn't really indicative of a broader "issue". Components fail. They get replaced. Life goes on. It sounds like you've got a good dealer that's taking care of you. Best of luck.
03-22-2016, 09:14 PM | #18 |
2JZ-GTE
3005
Rep 3,986
03-23-2016, 09:13 AM | #19 |
Rep 1,240
03-23-2016, 09:18 AM | #20 |
Rep 1,240
Learned this morning that the coolant pump is different for production dates Sep 2015 and later. Old part number (11 51 2 379 782) appears to have been superseded with a new one (11 51 7 643 067) on RealOEM and a couple of other websites.
03-24-2016, 02:45 AM | #22 | |
Rep 209
Turns out that the water pump had been throwing fault codes for quite some time (months) without ANY indication to the driver that something could be wrong. No lights on the dash, nothing. And then the car put him in danger. He lost trust in that car and the BMW brand that day. BMW could have designed the car such that the driver could get more than a few seconds warning of critical failure when the fault code log that has to be scanned in the shop showed a clear and definitive pattern of impending failure. At least with a mechanical pump there are obvious signs that it's going bad. |
340i, b58, coolant leak, water pump, water pump failure |
