12-03-2020, 10:55 PM | #1 |
Rep 170
False Alarm?
Hope someone can provide some insight into this issue.
My wife's 2014 335i alarm seems to be randomly going off. I've seen other threads (of older cars) where the switch in the hood is found usually by the hood shock area (and would disconnect to see if that's the culprit). But I can't seem to find any on this car. Or could it be something else? Thanks! |
12-04-2020, 06:09 AM | #2 |
Rep 500
Does it happen when it's cold? A little bit of water on the sensors could be freezing, preventing them from touching properly, setting off the alarm randomly. I know, seems like an odd guess from me but it happened to me on my previous car 🤷🏻*♂️!
12-04-2020, 11:13 AM | #4 |
Rep 170
Thanks but Honolulu doesn't quite reach freezing temps! LOL!
12-04-2020, 12:11 PM | #6 |
Rep 833
Drives: BMW F36, E36, E93
That's the way
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
12-04-2020, 12:16 PM | #7 |
Rep 170
Thanks
I’ve actually tried doing that last night to give it a try. But is there verification that the interior motion sensor has been disarmed? |
12-04-2020, 12:20 PM | #8 |
Rep 1,288
I'm sure you didn't but did you leave anybody in the car after you locked it? I locked the doors out of habit while refueling and my son was in the car and it set off the alarm... I tested it again with him and sure enough he just moved his arms around and set it off...
12-04-2020, 12:27 PM | #9 |
Rep 180
I think the LED under the mirror is supposed to do a slow/long blink to confirm. I've tried to deactivate the alarm countless times with no success. I'm wondering if cars sold in the US have it disabled for some reason.
12-04-2020, 12:40 PM | #10 | |
Rep 170
12-04-2020, 12:41 PM | #11 |
Rep 170
Nope I don’t think that happened as I was watching the led. But I’ll try doing it again.
12-04-2020, 02:01 PM | #12 |
Rep 2,807
Drives: F33 430 and F39 M35i
Cars sold in the US still has it. My dash cam fell and set it off. Also I had the top down and alarm on and threw some stuff in the car and it set the alarm off.
12-04-2020, 09:26 PM | #13 |
Rep 143
I just was in the shop for a similar issue, and it was rodents that had chewed the wires. Was getting miscellaneous false alarms. Noticed the red indicator lamp blink quickly for the first 10-15 sec then slowed to a steady blink. Also there was no chirp upon locking even though I had that toggled on. The fast blink meant that the car was not recognizing something as closed. Interior motion sensor still worked, so I thought it could be the hood latch switch as many speak of. In the end the dealer sent me the picture of the chewed wires and I had them fix it. All working now.
12-05-2020, 12:21 AM | #14 | |
Rep 170
I'll try to check the wiring too. But does anyone know where the hood switch is on the F30? Thanks |
12-05-2020, 08:12 AM | #15 |
Rep 1,560
I think you can pull the codes (with a good code reader) and it will tell you which sensor is setting off the alarm.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
12-05-2020, 08:28 AM | #16 | |
Rep 180
I just tried the procedure on a family member's F25 X3 and it seems to work. I pressed the lock button a second within 10 seconds and the LED stayed illuminated for about 2 seconds before 10-15 very fast flashes. |
12-05-2020, 11:11 AM | #17 | ||
Rep 143
I did not have any error codes which my generic OBDC II could detect. I guess a better code reader may have detected. Also, if your battery is older, that could pose issues with the false alarms. Where the rodents had chewed the wires in my car was up behind the rear wheel well, so you'd need to remove the panels to access that area, but the issue could be anywhere. You could also check if there is a blown fuse. The dealer replaced fuse 103 in addition to the wiring fix. I believe the alarm is first controlled by the FEM then the REM along the path of checking.
12-05-2020, 06:20 PM | #19 | |
Rep 2,807
It does. I had to do the second press while holding my key near the windshield for it to turn in the interior sensors off. Whenever I leave the car with the top down I have to turn the interior sensor off. it's the only way i can get it to work. maybe it's a vert thing on my car. |
12-05-2020, 07:45 PM | #20 |
Rep 170
Just scanned codes.
Came up with alarm activated and panic alarm. One instance each. Also came up with CD0487. Did a search, seems as though many people mention this fault code but no one ever mentions how they corrected or what specifically it is. I'm guessing that even though my wife seems to think the alarm is going off randomly I suspect someone is bumping into the car and triggering the alarm. |
12-07-2020, 08:21 AM | #21 |
Rep 1,560
Isn't the panic alarm activated by the key fob?
05-11-2023, 12:01 PM | #22 |
Rep 1,700
My alarm has been intermittently going off as well. At least 5x this morning, but prior to that it was weeks ago it happened. I just put the F31 on a CTEK battery tender now, ill leave it for a few hours and see if that helps. I do have a sunshade up on it most of the time, but would be random to trigger the alarm now. I've tried to disable the interior motion/tilt sensors as well.
Could it be hood latch like on the older generations?
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
