01-25-2016, 10:04 AM | #1 |
Rep 49
Dust behind plastic cover to dashboard
I've had my 2015 F33 since April. I dust/clean up the interior about once every 3 to 4 weeks. I am very careful not to wipe the plastic in front of the dash or the temperature display as I can tell they will scratch easily. However, a small amount of dust has found itself on the inside of the speedometer display. I am tempted to unscrew the piece (I notice there is a screw at the top), but I'm concerned about creating a bigger issue than I have now.
I'm doing my best to ignore it, but it is prevalent in the right sunlight and driving me a bit nuts. Has anyone had to remove the plastic to clean behind it? Last edited by abinder99; 01-25-2016 at 04:04 PM.. |
01-26-2016, 12:10 PM | #2 |
Rep 391
I haven't done it yet, but I've heard you just have to take out the two torx screws at the top and pry the clear shield off. I would suggest using rubber gloves to avoid leaving any finger prints and a can of compressed air to get rid of the dust instead of a cloth. All the plastics in the cluster look very prone to scratches/smudges.
floridaorange10126.50 |
02-01-2016, 02:00 PM | #3 |
Rep 27
If you end up removing the cover, please post how it went.
I have marks on the inside (by the trip odometer reset button). It drives me nuts. Called my dealer and they said that the cover can't be ordered as a separate part and the entire cluster would need to be order. |
02-02-2016, 09:07 AM | #4 |
Rep 1,568
I have a similar dust issue with my 13 335. The F-30 Bentley manual is supposed to be released in Mar. Hopefully that will have some guidance on removing the instrument cluster and the clear lens,
06-20-2016, 09:53 PM | #6 |
Rep 3,622
I have this too. Annoying
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
07-02-2016, 08:20 AM | #7 | |
Rep 49
10-21-2018, 11:30 AM | #10 | |
Rep 165
12-03-2018, 12:42 AM | #11 | |
Rep 905
12-11-2018, 09:59 AM | #12 | ||||
Rep 165
04-21-2019, 12:13 AM | #13 | |||||
Rep 165
04-23-2019, 07:47 AM | #14 | ||||||
Rep 165
05-11-2019, 05:46 PM | #15 | |||||||
Rep 165
