BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Coilover the Msport pakage suspension
European Auto Source (EAS)
      04-02-2019, 05:35 PM   #1
F30Legacy
Drives: Bmwf30 320i M-Sport
Hey.. i would liketo know if its agood ideato change the M-Sport suspension to adjustable coilover.. currently using the stock M-Sport suspension on my f30 320M-Sport.. im thinking about getting adjustable suspension.. how is it going to affect the preformance Thanx!
      04-03-2019, 12:05 PM   #2
cfm56d7b
What is your budget for the suspension upgrade?
      04-03-2019, 12:29 PM   #3
F30Legacy
About $1k?
      04-03-2019, 12:58 PM   #4
bmw22915
Drives: 440xi GC
About $1k?
Hmm. Just the B14 coilovers from Bilstein will run you a tad over 1k. Then factor in install labor unless you plan to do it yourself
Other coilovers will run you way above your budget. Unless adjustability is crucial for you, perhaps some Bilstein B8 struts with Eibach pro kit springs will be a better alternative
      04-03-2019, 01:04 PM   #5
cfm56d7b
About $1k?
Other coilovers will rum you way above your budget. Unless adjustability is crucial for you, perhaps some Bilstein B8 struts with Eibach pro kit springs will be a better alternative
@bmw22915 covered all items more than well. One more item to consider: depending on when the last four wheel alignment was done, you may have to factor it in.
      04-03-2019, 07:09 PM   #6
F30Legacy
About $1k?
How about preformance wise let say i change the m suspension to adjustable coilover is it going to be better than the msuspension? And any advice which coilover are good under $2k
      04-03-2019, 07:44 PM   #7
M4_GTS
Hong Kong
855
Drives: M4 GTS
coilovers under 2k
- KW V1, V2, V3
- Bilstein B14, B16
KW will ride softer and Bilstein will be firmer.
Originally Posted by FMLYSDN View Post
You're a dick. Oops. Did I just say that?
      04-03-2019, 09:13 PM   #8
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Definitely change the suspension. The stock M Sport suspension is too compliant. Don't get cheap coil overs though. If you're going to do it, get decent stuff.
      04-05-2019, 12:08 PM   #9
Jasbo
Jasbo's Avatar
Drives: 2014 335i M-Sport
not to hijack the thread, but arent some M-Sport susp packages active dampered? How can you tell what you have?
      04-05-2019, 01:17 PM   #10
andino
Drives: F31 328i xdrive
Put the last 7 of your VIN into a vin decoder site. If you have active M suspension or something, then you have the active dampers.
2016 328ix F31 | Bilstein B14 PSS | MPBBK | ER Catted Downpipe | REMUS Sport Exhaust | VRSF Chargepipe | G-Plus FMIC | BM3 Stage 2 | K&N Drop In Filter | KC Front Strut Bar | Superpro camber bushings | BMS OCC | Millway Camber Plates | KMAC Monoball | KC RSB
      04-18-2019, 02:42 AM   #11
F30Legacy
So what does it mean?
      04-18-2019, 10:05 AM   #12
alohasurftoad
Drives: 428i gran coupe
You do NOT have adaptive suspension.
