BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > I got an OEM M-Performance LSD for $455.
      06-14-2019, 04:48 PM   #23
IK6SPEED
IK6SPEED's Avatar
Drives: BMW M3 / AH3
Originally Posted by bimmer456 View Post
It's doubtful it's compatible with G20 as it is a completely different car.
Yet many parts from the E90 335i work on the F30 335i and that was a "completely different car" as well.
As realoem still does not list the diff for the G20s, right now it's an unknown.
However, the G20 specs for the 330 still show it using a 2.81 final, just like the F30 LCI.
If I'm not mistaken, believe the G series uses an electronic torque-vectoring LSD, they dubbed a M Sport differential, similar to the M cars now.
So if that's the case, I'm 100% it won't work.
I've seen BMW Group's press release: "the new M Sport differential. Through a targeted locking effect on the rear axle, the electronically controlled system, which is linked to the DSC stability programme, creates the optimum prerequisites for even more dynamic acceleration out of bends."
M Sport Differential - (2VF)
Although, are ALL G20 using these or just the M340?
Not 100% sure. Sorry :
Yes, that's the issue.
A lot of unknowns at this point....despite someone else mad about info on this forum not being absolute.
Stable: F80 / AH3
Past: F80 ZCP / F22 M235i / E89 35is
      06-14-2019, 06:12 PM   #24
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Ok, now I've officially confirmed that it's part of the ZTR – Track Handling Package (2NH – M Sport Brakes, 2T4 – M Sport Differential) for $2,400 on the G series 330i, standard of the M340i.
Slightly differently option code for some reason (2VF vs 2T4) but they both appear to operate the same way, electronically.
It looks like an electronic factory LSD is an option for all new non-M models. A generation too late, I might add
I pretty sure that was the case before but I wanted to confirm it.
      06-14-2019, 06:29 PM   #25
IK6SPEED
IK6SPEED's Avatar
So we complete the circle....what is the standard OEM diff on the G20?
If it's the same diff 2.81 diff as the F30 LCI, then the F30 LCI 2.81 Final MPerformance LSD would NOT go on sale in 5 years.
If it is not compatible, then the MPerformance LSD for F30 LCIs will most likely will go on sale then.
Such a long path to get right back to the same place 6 hours later.
Stable: F80 / AH3
      06-14-2019, 07:38 PM   #26
Jungatron
Jungatron's Avatar
122
Drives: 2015 335i Sport
Originally Posted by controllerplus View Post
may be old news, but ecs is selling the lsd for very cheap. all other vendors are sold out. price went up a bit but supply and demand plays a factor.
I recieved it for $455. it used to be over $2300 I'm ecstatic to have it.
Got one a month ago and it's installed and just finnish the 500 mile break in. Sport + is harder to break the tires loose. Lots more grip. I'm a big fan so far
2015 - 335i RWD A8 | MPE, MP LSD, M sport Wheel, M Sport Suspension, 245/35/18 square, BM3, VRSF Chargepipe |
      06-15-2019, 06:31 AM   #27
bimmer456
Drives: 340i
$2300 for that price you cold just get an x drive car if you want more traction off the line. Even with the new price plus install you're costing possibly more than the additional cost to get an x drive when new and less if used.
      06-15-2019, 08:51 AM   #28
Xchrisxxxx
Drives: 2013 335i M-Sport
Got mine the day they went on sale, installed a few days after receiving, I didnt do the recommended 500 miles, I did the 30 circles in each direction at 1k rpm. Car is a whole new animal honestly. I'm FBO on big boost 3.4+ and a LSD is just what my car needed, feels Xdriveish out of the hole and feels like a true M car around tight bends, highway on ramps have never been so fun before 😌
      06-15-2019, 07:09 PM   #29
controllerplus
Drives: e46 m3
I bet that's insane! how do you like the 3.4 kit? thinking about going from ps2 to that.
      06-15-2019, 10:34 PM   #30
Xchrisxxxx
I love it. The boost lag is noticeable, but with brake boosting there is no lag, it's a dual ball bearing turbo so it spools pretty quick, and the power is insane, it wants to keep going and going , I feel like if I could rev to 10k rpm the car still wouldn't fall on Its face. Ps2 maxes out at 550ish whp depending on setup, and you are really stressing that turbo out, but this kit doesn't even bat an eyelash at 600+ whp. It feels like a supra in a way.
      06-16-2019, 03:39 AM   #31
controllerplus
Drives: e46 m3
definitely going to look into it in the future. I'm just worried about my transmission at that power Haha
      06-17-2019, 09:06 AM   #32
Jungatron
Jungatron's Avatar
122
I will agree with the car feeling totally different. At stop lights now the tires grip so much more when I punch it, and when it does slip its catches itself quicker and I see much less traction control light. I did the 500 miles before I did some hard launches and I really feel the grip has been improved.
Hard corners are a lot more fun :-)
      06-17-2019, 12:22 PM   #33
limited60
Drives: 2018 330i xDrive Sedan
Can someone help this new-to-BMW owner out?
LSD?
LCI?
PS2?
I keep seeing these, but keep not knowing what they are. I can infer a bit, but I don't think it's helping any...
      06-17-2019, 02:22 PM   #34
Xchrisxxxx
LSD?
LCI?
PS2?
Lsd = limited slip differential, usually our cars have open diff which doesn't put all of the power to both wheels all the time, limited slip puts equal power to both wheels
Lci = life cycle input aka minor redesigns, here's a post comparing pre lci and post lci f30 https://f30.bimmerpost.com/forums/showthread.php?t=1124274
Ps2 = pure stage 2, it's an aftermarket turbo solution that used the factory turbo housings so it's a direct bolt on solution that looks stock from the outside but has larger internals for greater horsepower.
      06-17-2019, 03:51 PM   #35
TheShadow
Drives: 335i M sport
Just got info from ECS about 2 hours ago that theres only 2 left in stock and then they wont be receiving anymore.
IK6SPEED3144.50
      06-17-2019, 06:10 PM   #36
Xchrisxxxx
😱😱😱 Damn I feel bad for anyone who misses out
      06-17-2019, 06:34 PM   #37
Kraftwerk
Kraftwerk's Avatar
Drives: 2015 335i M Sport
I just ordered from BMW Portland Parts for $513 shipped. List price is $492. Which is a great deal.
I think they have one more in stock.
https://www.bmwpartslink.com/oem-par...al-33107555607
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
      06-17-2019, 09:19 PM   #38
TinkyWinks
TinkyWinks's Avatar
32
Drives: 2014 BMW 335i
Thanks for the update! Kicked myself for missing the first batch that sold out at this price. Just ordered from ECS.
      06-18-2019, 12:56 AM   #39
controllerplus
Drives: e46 m3
got it today. cant believe I paid $455
