BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Engine bay water drainage
      06-14-2019, 10:57 PM   #1
phoizgood415
Drives: 435i
Donít know where else to post this so if a mod can move it to the appropriate forums I would appreciate it,
Otherwise, I was washing my car and popped the head to do some cleaning and I noticed on the passenger side of the engine bay, water was draining right onto a bunch of wires!!
I know this doesnít shouldnít be right. Luckily there was a debris of leaves blocking the drainage hole so I was able to use a microfab to soak the puddle of water up before it spilled onto the wires right below the drainage hole .
This is a f32 so Iím asking if others f32 engine bay looks similar to this and if your drainage hole is right above a bunch of wires. For now Iím goibg to plug that hole with something so when it rains it doesnít drain right o. Top of it .
In picture 2, that was where the leaves were and the water was stuck there. If there were no leaves blockage there, water would be running down below right on top of those wires (pic 3)
      06-15-2019, 11:37 AM   #2
John in VA
Drives: 2015 228i M Sport
You're OK - drains are there for a reason, but our F30 held a lot of water on those plastic parts when it rained or was washed. Dry it if you feel like it. Keep the leaves, etc., out of the way.
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system
      06-15-2019, 01:31 PM   #3
phoizgood415
Drives: 435i
Iím not worried about the puddles, if you look at pic 3 and 4, youíll notice the water exit/drips right on top of those bundled wires right there, I donít think that is correct .
Can someone with a f32 n55 confirm for me that the passenger side engine bay Is indeed like that? I suspect I might be missing some extra rubber piece that leads the water away from wires, Iíll even PayPal you $3 if you can send me a pic.
      06-15-2019, 06:11 PM   #4
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
I donít believe there is a drainage hole in that depressed area (which is there for the wiper in right hand drive cars) unless a hole was previously drilled to allow water to drain from that depression. I myself did drill a hole there but made sure it drained away into the proper drainage area. You should plug that hole if itís not draining into the drainage area. Are you the original owner?
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSptPkg AlpWhite
      06-15-2019, 08:48 PM   #5
phoizgood415
Drives: 435i
Iím not the original owner. Yes there is a hole in that depression area and I donít think it should be there. I prolly need to find a rubber stopper to fit that hole, meanwhile does anyone know what those bundle of wires are? I been driving like this for over 20k miles and now Iím paranoid those bundle of wires maybe compromised from the water exposure. Any idea how to check that? Itís coming through the wheel wells and looks like itís going to the hood, looks like itís for the windshield sprayers.
      06-15-2019, 10:05 PM   #6
The Airman
Drives: 2018 330e
I don't think that cowl drain is dripping water on those wires under normal use. It's similar to the gutters on your house. It drains the water to a screened drain deep down in there.
I can't stress enough on keeping that area clear on leaves and crap. That cowl drain system will cause issues when clogged.
Here's a picture of mine from last year when a tree decided to crap on me. It took me an hour with a shop vac and a small hose taped to end to suck out the cowl drain.
Dave
BMW CCA #67486
