05-14-2020, 09:34 AM | #288 |
Zae Ortiz
Rep 3
need help coding from the start
05-14-2020, 09:53 AM | #289 | |
Zae Ortiz
Rep 3
i would love to know the step by step coding process to retrofit the 6wb from a 6wa in a 2016 328i (if i buy the cluster from ebay). can someone help me with that? |
05-15-2020, 02:30 AM | #290 | ||
Rep 3,886
05-22-2020, 04:36 AM | #291 | |
Rep 3,886
I was quite disappointed. My expectation was that it delays the disappearance of the welcome screen, i.e. prolonging its visualisation. What it actually does is delaying the appearance, whereas it still disappears just after a second or so! So when you open the door, the instrument cluster is dark. It goes on a few seconds after that, flashes the welcome logo quickly and loads the instruments.... I left it like this to see how I perceive it, but I am not sure I like it.... gives me a Windows 95 slow PC start feeling... as if the cluster needs half a minute just to power on.
05-24-2020, 11:23 PM | #292 | |
Rep 742
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
05-26-2020, 03:28 PM | #293 | |
Rep 56
KOMBI_CIC should be kombi_high for 6WB (left) and kombi_mid for 6WA (right). Are the others ok? I have just retrofitted 6WB, looks like everything ok, but as you said, some missing features I might notice later. |
05-27-2020, 05:54 AM | #294 | |
Rep 2,302
i just checked the values and it's a bit confusing. With my old Evo ID4 + 6WB is the value Kombi_CIC = Kombi_mid. For my new Evo ID6 + 6WB is the value Kombi_CIC = Kombi_high. If everything works you can leave it that way. If you want to test some things or you have problems you can try to change this value. But I'm honest, I don't know exactly what this value really does. |
chr12.00 |
05-27-2020, 06:48 AM | #295 |
Rep 56
My car is from 07 2014 with HU_ENTRYNAV and BKOMBI.
Retrofitting 6WA was simple: VO code 6WA, code HU_ENTRYNAV, read ECU, now KOMBI appears instead of BKOMBI, inject CAFD, code KOMBI and that's it. Retrofitting 6WB is more complex. - VO code 6WB, code HU_ENTRYNAV, read ECU, now BKOMBI disappears and nothing in place. - FDL code Kombi_CIC = high, EXTERNER_MOST = aktiv and EXTERNE_MOST_DIAG = aktiv, read ECU, now DKOMBI appears, inject CAFD, code DKOMBI. Now it works, but it does not have full functionality. I also FDL code DKOMBI: NAVI_NBT_ENABLE = kein_nbt; Kompass_Graph_Enable = aktiv HU_ENTRYNAV: SETTINGS_INFO_DISPLAY = aktiv Now looks good, but I will try to play with other values found in this topic to see what happens. What I do not understand is why coding HU_ENTRYNAV and DKOMBI after VO code 6WB does not put the proper values, so FDL code has to be done afterwards. |
05-27-2020, 01:21 PM | #297 |
Rep 56
Yes, this should be the reason.
I have also tried to change zeitkriterium in FA, but the result is the same, HU_ENTRYNAV do not see DKOMBI after VO coding, without proper FDL coding afterwards. |
05-28-2020, 07:27 AM | #298 | |
Rep 3
Does anyone have a solution to this problem? I experience the same in my F11 with 6WB and NBT Evo ID6 retrofitted. |
05-29-2020, 06:10 AM | #299 |
Rep 3
Just wanted to say that I found a solution to this problem. I changed NAVICOLOR_TABLE from "neue_farbtabelle" to "farbwelt_id5" and now it looks like below
06-18-2020, 10:06 PM | #300 | |
Rep 12
Max |
06-18-2020, 10:09 PM | #301 |
Rep 12
06-19-2020, 12:41 PM | #302 |
Rep 2,302
06-22-2020, 06:23 PM | #303 |
Rep 8
Does anyone know how to solve disapearing HUD.
I have cic navi professional, and hud just dissapears randomly while driving Carly have errors: B7F6E4 hud: error in display backlighting B7F6EC faulty recieve image data from the combi:hud B7F7B9 hud wrong version installed I assume that is coding error is causing this Please help |
06-30-2020, 02:37 PM | #304 |
Rep 15
Hi Guys,
Helpful thread so far. I have the same problem as described above. Retrofitted a 6WB on a 07/2012 F30 with HUD AND HUH_CIC. Everything works fine, also HUD. But after 10-20 minutes of driving, the HUD disappears and doesn't come back up. Anyone with a solution on this? Help would be very appreciated! |
06-30-2020, 03:54 PM | #305 | |
Rep 2,302
But I just checked the parts catalog and there is the HUD with changed hardware from 07/2013. So I think there is no other solution for you other than swapping the HUD with a newer one. |
07-04-2020, 12:13 PM | #306 |
Rep 41
07-05-2020, 02:12 AM | #307 | |
Rep 1
the same
@atzebmw: Fishel2997 might have the newer version of the hud. Nevertheless the hud disappears... Last edited by f30fan4u; 07-05-2020 at 02:31 AM.. |
07-05-2020, 05:21 AM | #308 |
Rep 2,302
