BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6WB coding tread
      09-15-2018, 05:52 AM   #67
otromen02
Drives: BMW F30
Hi, I'm trying to retrofit used 6WB to my F30 316i. I've added 6WB in the VO, but I can only see BKOMBI, not DKOMBI.
Also my original cluster only have 1 connector, in 6WB it has 2. I'm missing the green/black connector. Will it work? What that connector for?
I've been searching high and low, hopefully someone can point me to the right direction
      09-15-2018, 06:58 AM   #68
larrybml
Drives: X3 F25 2011
You will need that MOST connection. You need to insert kombi into car’s MOST circle. Otherwise it will not be seen and coded.
      09-15-2018, 07:10 AM   #69
atzebmw
Drives: BMW 335XD F30 LCI
First code your headunit with 6WB.
After that DKOMBI will appear.
Edit:
And like larrybml said you need the most connection.
      09-19-2018, 08:45 AM   #70
erixazix
Drives: F30 2013
Hi, upgraded my 6WA to 6WB, all works fine a part of Navi on dasboard or any other options that used to be on 6WA also noticed that on my NBT settings i missing oprion - Instrumental cluster
      09-19-2018, 10:46 AM   #71
erixazix
Drives: F30 2013
SOLVED by setting DKOMBI => NAVI_NBT_ENABLE = kein_nbt.
      09-19-2018, 11:02 AM   #72
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Did you FDL Code KOMBI_CIC = kombi_high?
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      09-19-2018, 03:31 PM   #73
erixazix
Drives: F30 2013
Thanks for your reply,
Yes Kombi coded to Kombi High
Also just coded
DKombi - NAVI NBT ENABLE so sat nav works on dash, but still missing - Inst. Cluster in settings
      09-19-2018, 04:00 PM   #74
shawnsheridan
Also just coded
Sorry, but I don't really understand exactly what it is your are missing. What is "Inst. Cluster in settings"?
      09-19-2018, 05:52 PM   #75
erixazix
Drives: F30 2013
Shawsheridan, many thanks for your help.
I worked out what was missed(not coded), now works all as it should.
So what i mean by - Inst. Cluster(to choose what will show up on your KOMBI) - In setting on NBT where is options:
Control display
Time/Date
Language/Units
etc.
And also should be Instr. Cluster Display - This was missing
Now by Actived CAFD 3000 SETTINGS_INFO_DISPLAY - all works fine
Wanted to share my learning :happyanim
Would add some photos but not sure how to add lol
      09-19-2018, 06:05 PM   #76
shawnsheridan
I worked out what was missed(not coded), now works all as it should....
      09-23-2018, 07:00 AM   #77
dincic
Drives: Bmw f80
Hi friends. Please help me with 6wb on f34.
car manufacture year 2013.07
I successfully coded it but with one problem...
I got error: Tow hitch !!!
Please help me with this issue ) Regards
      09-23-2018, 07:05 AM   #78
atzebmw
Does the car have a tow hitch?
      09-23-2018, 07:09 AM   #79
dincic
Drives: Bmw f80
yes
      09-23-2018, 07:18 AM   #80
dincic
Drives: Bmw f80
Also tell me please about cars with bkombi and without most!! Dkombi cant be identified in esys, i read somewhere that to make it visible firs need to delete Bkombi from SVT and write to car again svt without bkombi and then dkombi will be visible for coding.. is it true ?
      09-23-2018, 07:24 AM   #81
atzebmw
yes
OK, then you should check if the "3AC" is still in the FA included.
If not, edit the FA and add the "3AC" and code again the Kombi.
Or you can manually check whether these values are set correctly:
KOMBI FPK_I12 > ERM_Konfiguration 3004 > DISP_CC_BYPA_02_ALIVE = aktiv
KOMBI FPK_I12 > ERM_Konfiguration 3004 > DISP_CC_BYPA_02_CRC = aktiv
KOMBI FPK_I12 > ERM_Konfiguration 3004 > DISP_CC_BYPA_02_TIMEOUT = aktiv
KOMBI FPK_I12 > ERM_Konfiguration 3004 > STAT_ANHAENGER_TIMEOUT = aktiv
dincic1.50
      09-23-2018, 07:26 AM   #82
atzebmw
Withou MOST the Kombi will not work correctly.
Otherwise first code the HU_NBT and then the DKombi should be visible.
After that code the DKombi.
dincic1.50
      09-23-2018, 07:29 AM   #83
dincic
Drives: Bmw f80
I connected dkombi to hu_nbt with most but it still invisible for coding
      09-23-2018, 07:32 AM   #84
atzebmw
Did you already code the HU_NBT?
      09-23-2018, 07:39 AM   #85
dincic
Drives: Bmw f80
I will check in 10 minutes. My customer will give me teamviewer
      09-23-2018, 07:40 AM   #86
dincic
Drives: Bmw f80
Hu_nbt2 is also retrofited, maybe this is prob ?
      09-23-2018, 07:42 AM   #87
atzebmw
No, i don‘t think.
      09-23-2018, 08:12 AM   #88
dincic
Drives: Bmw f80
I code hu nbt and also try to delete bkombi from svt and anyway i dont see cluster
