06-19-2017, 10:55 PM | #1 |
Rep 308
Engine oil leak. need help ASAP
First time,i did an oil change on my F30 that has plastic oil tank.
Oil is leaking from where the plastic drain plug is. (Tightened it and leaks again) I do have to say that i didn't replace the drain plug with a new one.. Is it really necessary that i change the drain plug every oil change and this may be causing the leaking? This is my first time screwing up oil change after many different cars.. it's my first time handling a plastic oil tank. Is it possible to reuse the oil after i drain it and replace the drain plug with new? Please let me know ASAP. i need to take road trip tomorrow.
F30 328i sedan
06-19-2017, 11:04 PM | #2 | |
Rep 5,984
06-19-2017, 11:24 PM | #3 | |
Rep 308
Also needed some effort to put the plug back on. Is this normal for plastic pan and plug? The plastic BMW used on pan and plug, are they considered pretty durable? I hope that i didn't strip the thread. Probably didn't but so much concern at this point. Time is limited. This oil change was such a mess. i put the oil filter gasket in the wrong place and oil splashed everywhere over 2 days. Lost about 4 qts of Castrol. Thanks to BMW for throwing out the Low Engine Oil light after losing 4 qts. Now i basically have to do another oil change..another 5 qts of Castrol.. First time ever screwing up an oil change all after Camry, Nissan, Inifiniti, Audi and Scion.
F30 328i sedan
06-19-2017, 11:24 PM | #4 | ||
Rep 74
To weigh in, I would use new oil. I would be worried what I picked up.
2015 328xi JB4 and Injen CAI
06-19-2017, 11:34 PM | #5 | |
Rep 5,984
06-19-2017, 11:50 PM | #6 |
Rep 308
RWD has stupid plastic pan -_-
F30 328i sedan
06-19-2017, 11:51 PM | #7 | |
Rep 308
I decided to do oil change myself this time after 4K miles. Oil was so dirty and black. Not sure if BMW used cheap oil or what but after 4 K miles how can it be so dirty
F30 328i sedan
06-20-2017, 12:08 AM | #8 |
Rep 5,984
Maybe they didn't even change the oil. After I brought my car in, not only did they not put enough oil, they forgot to reset the CBS so I did it myself! I did bring it back to have them fix the problem, but I had already reset the CBS the night before.
06-20-2017, 12:34 AM | #9 |
Rep 308
Maybe they never changed it thats why yhe drain plug was hard to remove and made loud squeaking noise -_-
F30 328i sedan
06-20-2017, 02:23 AM | #10 |
Rep 3,216
You don't say if your car is a diesel or petrol (hint, drives 'bmw' in the profile bit isn't very helpful), but a few hundred miles after an oil change the oil in a diesel engine is pretty black.
I kinda like the irony in how you decided to do the job yourself, because you didn't trust BMW to do it properly, and then ... you didn't do the job properly. |
06-20-2017, 03:06 AM | #11 | |
Rep 308
Bmw did it for free oil change.
F30 328i sedan
06-22-2017, 06:37 PM | #12 | |
Rep 403
07-13-2017, 01:31 AM | #13 |
Rep 74
Hi there,
I drive a MY2012 F30 with N13 engine (1.6L 100kW). Yesterday my car throw its second "Low coolant" warning after the full replacement of cooling housing and piping ~2 years ago. I drove to the dealership for maintenance. They informed me that, there were various locations were the coolant leaked and also they observed various locations of oil leak. This car was serviced ~4500km's ago and is only 90k Km now. They say, they need to change oil pump, oil filter housing, oil pipes and etc. Of course they deny to cover it because the car is 5 years old. Can you please share any specific or known issues on this regard (not necessarily the N13 engine). I would like to learn if BMW HQ has published a recall on any of the contents failed in my car. |
