05-02-2020, 07:35 PM | #1 |
Rep 117
2014 N55 Fuel Supply + Drivetrain malfunction
Hi there everyone,
Hope everyone is doing well during these times. Just wanted to ask everyone for their input as I'm currently trying to solve an issue with my 2014 335i. Some background information, it's a FBO 335i that was running a custom Gintani tune. Was running absolutely flawlessly up until 2-3 months ago where I died in the middle of the highway with a Fuel supply fault, and then followed by a Drivetrain malfunction warning and the car stutters and dies and gets put into N gear. Read the code and it was an intermittent HPFP code. Figured that it was the issue so I replaced it with an OEM one (These are expensive holy). Ran it for about 3 hours before I got the error again, and it died. Another thing to mention is that I have a Stage 2 LPFP from Fuel-it!. But I have doubts that the LPFP could be the issue. Something that I have noticed personally is that it happens when the tank is right under half, and that it doesn't happen when it's full. I've tried to read the code the first time but nothing came up, which was weird. Car pulls hard when needed, tried to switch the maps to see if that was the issue but it still persists. A wonder that I have currently is that, is the car thinking the tank is empty and just cutting the power out? I would love for some input as I'm quite lost. Thanks guys! |
05-02-2020, 07:40 PM | #2 |
Rep 7,598
Well, given that the issue seems to be related to the fuel level and low pressure supply, i would immediately be suspicious of the LPFP... who installed it? Does it happen every time the tank gets under half, or it just never happens when its above that level? Could be an issue with the LPFP pickup, not the LPFP itself.
LPFP is not really needed unless you are going to run PI, so was there a reason you installed it in the first place? How is your EKP? |
05-02-2020, 07:47 PM | #3 | |
Rep 117
I had a shop here install it, worked flawlessly during my time. The car has about 84,000Km on it and I installed it when it was at about 50,000Km. Thanks for clarification. Thinking about it now after, I might also suspect that it's the pickup. Pump itself is highly durable from what I've been told and such, so I don't think that there should be any issue with the LPFP itself. EKP is normal. Everything runs normally other than that. Do you think I could swap out the pickup from the OEM pump into the Stage-2 Pump? I had plans to run PI this summer but given the whole situation right now, it seems far off into the distance. |
05-02-2020, 08:05 PM | #4 | |
Rep 7,598
05-02-2020, 11:33 PM | #5 | |
Rep 117
But from what the current outlook is like, it's the pickup as well. |
04-13-2021, 10:07 AM | #6 |
Rep 88
were you able to figure out the issue, i also have fuel it stage 2 lpfp and have been having this fuel supply issue, started out turning the car off when i was driving. Then the car will turn on for 10 mins till it turns off again. tried swapping a oem used lpfp, and ekp and that didnt fix it any ideas ?
04-13-2021, 11:07 AM | #7 |
Rep 57
This sounds very similar to what I've been experiencing on my car with stock fueling. Above half tank no issues with similar conditions, under and there's a high chance it'll happen under load. Most recently was driving through Georgia on a steep incline a few ticks above quarter tank on cruise control + comfort mode (80 mph), it threw a drivetrain error and required a restart that cleared everything up and was fine until I found a gas station. I made sure to keep that tank above a half the rest of my drive. Another thing I've noticed is once the gas light comes on, my miles left drops very fast. So that got me thinking it could be sensor related, but idk been dealing with this for 3 years lol.
The codes it throws is 110001 - Cylinder injection cutout. Pressure too low in high-pressure fuel system. 11A002 - High pressure fuel, plausibility. Pressure too low. I'm running MHD stage 1 with FMIC currently, but it happens while stock as well. |
04-13-2021, 12:02 PM | #8 | |
Rep 869
04-13-2021, 02:46 PM | #9 | |
Rep 57
I also have no signs of the other typical HPFP issues such as rough idle, poor acceleration, or long cranks. |
04-13-2021, 03:15 PM | #10 | |
Rep 7,598
I do agree those does are not necessarily HPFP. As far as i know, there is no LPFP pressure sensor so a fuel supply issue to the HPFP can cause those HPFP codes. |
04-13-2021, 03:41 PM | #11 | ||
Rep 869
04-13-2021, 09:47 PM | #12 | |
Rep 57
Until my last trip, it happened at 2300 rpm around 80mph, but with a pretty steep incline. |
04-13-2021, 09:56 PM | #13 | |
Rep 57
04-14-2021, 01:15 AM | #14 | |
Rep 7,598
04-14-2021, 07:50 AM | #15 |
Rep 57
04-14-2021, 05:40 PM | #16 |
Rep 1,127
fill up your tank with gas and see how much it takes. If the sensor says 1/2 a tank it should take 7-8 gallons, if it takes say 15, the fuel level sensor is wrong.
04-14-2021, 05:59 PM | #17 |
Rep 7,598
But i think the issue might be his reads OK until half a tank. So that method could work, but a bench test of the actual sensor would be more accurate for diagnosing.
04-16-2021, 09:12 AM | #18 |
Rep 57
I came across this video
that shows how to test the fuel level sending units. My left tank was reading @ 170 Ohms and my right @251 Ohms. Not sure if this actually means anything since I can't find any information on them or find them in the technical training manual. https://www.bimmerpost.com/goodiesfo...owertrain1.pdf |
04-16-2021, 01:14 PM | #19 |
Rep 88
I replaced my lpfp with a used oem one and put the original ekp back and my car started and ran good now im sending my stage 2 fuel-it walboro 525 back to fuel it to get a walboro 450 to pull less amperage
04-16-2021, 03:48 PM | #20 |
Rep 57
Just to confirm you're saying things are running fine even with low fuel?
