04-03-2021, 03:54 PM | #1 |
Rep 7
b58 bootmod3 max cooling setting
hey guys,
Just wondering everyones thoughts on the bootmod3 max cooling setting... i live in canada so the winters can get very cold but the summers can reach up to 30-35 degrees celcius. (stage 1 340i no bolt ons) questions: 1) are there any cons or risks in using the max cooling setting on bootmod3 year round? 2) do any of you use this setting and have any comments on it? thanks in advance |
04-03-2021, 06:01 PM | #2 |
Rep 611
1) No, it works only, when needed.
2) Yes, on stage 1 93. Not much to comment, though. According to the oil temp gauge, the temperature is slightly lower while pushing the car for longer period (as spirited driving up to the mountains, or longer summer highway journeys in speeds above 120 mph). Otherwise, no change. |
04-05-2021, 12:15 PM | #3 | |
Rep 7
04-07-2021, 08:16 AM | #4 |
Rep 2,099
Would this make it take longer for the car to get up to temp?
I enabled it and went for a drive yesterday and It seemed to take longer. May just be me though.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
04-07-2021, 09:04 AM | #5 | |
Rep 532
so yes it takes longer to reach temp. not sure if this mode is good for the pump !! |
04-08-2021, 02:58 PM | #7 | |
Rep 839
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
Th3Walrus327.00 |
04-08-2021, 05:39 PM | #8 | |
DisplacementReplacement
381
Rep 1,085
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 Last edited by Jnat; 04-24-2021 at 07:16 AM.. |
04-29-2021, 12:17 PM | #10 |
Car Guy. Blown away by BMW.
Rep 13
I had the max cooling enabled on my Stage 1 BM3 tuned 340i xDrive and noticed that I could hear what sounded like a fan running constantly. I worried it would possibly prematurely wear the part (cooling pump?) so I disabled max cooling. I no longer hear the fan or pump sound. It almost sounds like the AC fan to me, so if anyone can confirm if that is the cooling pump, that would be great too. Hope this helps!
04-29-2021, 06:06 PM | #11 | |
Rep 1,448
3:05 mark, he takes off the oil/water heat exchanger.
2022 CT4-V Blackwing 6-speed
05-01-2021, 09:00 PM | #12 |
Rep 7
What are IAT's? Is there a post where all these acronyms are defined? I swear I can't read 2-3 sentences without reading some sort of acronym lol. Sorry fellas for the rant.
05-01-2021, 09:19 PM | #13 |
Novice
297
Rep 685
05-03-2021, 08:37 AM | #15 | |
Cheapskate
4442
Rep 4,992
john_f3016.50 |
05-03-2021, 06:07 PM | #16 |
Rep 1,448
Call me skeptical, but with BMW's history of failed water pumps, I'm probably going to leave mine OEM.
"Moreover, for the B series engines this enables the intercooler pump to be active at all times to lower intake air temperatures!" - Directly from PTF/BM3 Having the pump active at all times doesn't sound good to me lol.
540iSUP703.00 |
05-03-2021, 08:00 PM | #18 |
Rep 58
Mine just failed 2 weeks ago. Mechanical water pump replaced. About a couple months after the eccentric shaft was fixed. Hopefully that's it for me. Already out of warranty lol
05-03-2021, 09:59 PM | #19 | |
Rep 1,448
Us 2016's jut unlucky.
05-04-2021, 07:47 AM | #20 | |||
Cheapskate
4442
Rep 4,992
I turned mine off because I'd rather the car run at the operating temp it's designed for instead of dropping to less than 190F every time a do a pull. |
05-04-2021, 09:30 AM | #21 | ||||
Rep 1,448
05-04-2021, 01:43 PM | #22 |
Rep 58
Pump leaked where the bearing is. Service says it's worn out.
