BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Heated Steering Wheel Function Retrofit discussion and sharing
      11-19-2017, 08:58 AM   #89
accloginsell
Hi all,
i've retrofitted but dont want to VO code. Can someone maybe tell me the parameters?
Thank you
      11-20-2017, 04:28 AM   #90
talharama
Drives: F31 Step Auto Sports
Originally Posted by Tibass View Post
It all functions!
I didn't save the VO at the right way.
Thanks for all the help Talharama.
You are welcome.
Did you manage to make it work?
      11-20-2017, 07:56 AM   #91
talharama
Originally Posted by accloginsell View Post
Hi all,
Thank you
Dear you can't enable heating if you don't vo code.
Add 248 to FA and Code the following ECUs Fembody, ICM and Kombi.
      11-22-2017, 01:49 PM   #92
talharama
Originally Posted by gotomoto View Post
So i tried to do this. connected the cables as instructed. got a new heating button and not working. ISTA gives the error below. I tried my friends steering column switch. still not working. anybody has an idea?
I have got mine working, but what i have learned is that you need move the wires from the back of szl pin 9 and 11 to the unused pins on 1 and 3 on the back of the szl then you can get power in from the airbag connector on the front of the wheel.
Unfortunately i learned this after ordering new szl with heating function.
      11-22-2017, 01:50 PM   #93
talharama
Originally Posted by david51 View Post
hello
Before buying the next room (Switch unit steering column)
just use the unused connectors of the airbag:
+ slot 1 (red/Black)
- Slot 3 (brown)
must displacement connectors power and ground to the heated steering wheel
This is the one you need to follow to get this working. This is explained on the second post with pictures.
      11-22-2017, 02:38 PM   #94
talharama
I have swapped the szl to check if this works unfortunately didn't work, i think you definitely need new szl with heating function.
      11-23-2017, 09:14 AM   #95
talharama
Finally
https://ibb.co/dDnETR
https://ibb.co/jFa4v6
      11-26-2017, 08:38 AM   #96
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
so how did you manage to do that? can you help me?
      11-27-2017, 04:27 AM   #97
accloginsell
hello
- Slot 3 (brown)
Hi,
how can i activate this pins to get energy? As now there is no energy on them. Also tried with external 12V out of the car.
i have now these errors. Where can be the error?
Just coded 5AD and 248 to the whole car.
switch is installed and plugged into the SZL.
      11-27-2017, 09:15 AM   #98
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
here is the connection
brown wire to FEM module (A173 * 7B) slot 10
red / black wires to (Z7 * 5B) slot 1
Added to VO 248
right click and code
FEMBODY
ICM
KOMBI
      11-27-2017, 10:13 AM   #99
accloginsell
Hello
Added to VO 248
FEMBODY
ICM
KOMBI
Thank you
i have an already prewired as shown there. http://f30.bimmerpost.com/forums/att...1&d=1435935902
But there is no energy on it. Fuse 48 in the front is filled and okay.
Where could be the Error?
Also the Switch is not working als LED is not burning?... I have a normal SZL without HEating wires.
      11-29-2017, 01:23 PM   #100
r0b3r
Drives: Bmw F
error, delete.
      11-29-2017, 08:46 PM   #101
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you
did you encode like that ?
Added to VO 248
FEMBODY
ICM
KOMBI
      12-05-2017, 04:39 PM   #102
SpilltheBimms
Drives: F31
Hello everyopne.
I recently swaped my steering wheel ("big airbag enclosure" with the grey lower lip) for one with the CC buttons, which I did not have (and paddle shifters). I noticed that it has the heater controler and such, which was just a matter of luck. I bought the plastic under cover and the button, and I coded the function in.
However, it's not working.
I suspect the problem is in the switch unit steering column. Being the not very focused kind of guy, I forgot to just take a look and check the part number, when I had everything disassembled.
Today I found a switch unit steering column with high beam assist, which was another thing that I was looking for.
So, I'd just like to know if someone can tell me if this unit will work with the steering wheel heater function, as the ones mentioned in the first post. The PN is 61319351153.
This would solve both my "problems" (steering wheel heater, and high beam assistant).
The shop selling it shows it as a used F31 part, which is the chassis that I have.
Thank you very much for your time and help.
      12-08-2017, 01:10 PM   #103
macs
macs's Avatar
Italy
Drives: f31
Originally Posted by SpilltheBimms View Post
Hello everyopne.
No, it is not the right part, see here: http://www.realoem.com/bmw/en/showpa...59#61319351153
      12-11-2017, 03:03 PM   #104
SpilltheBimms
Drives: F31
Thank you very much
      12-12-2017, 06:46 PM   #105
Jhnblckwood
Drives: F30 2014 320i xdrive
Is this confirmed that u def need to buy new one if u have no other options? So airbag pins can't b used?
      01-08-2018, 01:25 PM   #106
PisuM
Romania
Drives: 320D
hi guys,
I was wondering if you can help me with some info. i did the retrofit on a bmw f30 2012 but at the moment i am missing the wire connector coming from the heating button to szl. does anyone of you know the code of that connector wire? i see from internet pics is a three wire connector but i am not able to find it anyware ( realoem etc. ) .
any advice will help.
thanks in advance!
      01-08-2018, 04:43 PM   #107
macs
macs's Avatar
Italy
Drives: f31
Originally Posted by PisuM View Post
hi guys,
thanks in advance!
I think it is not available alone, it is part of the button. Maybe you can find one on the net but not at dealer.
      02-22-2018, 05:33 PM   #108
TeaAndBiscuits
Drives: 325D F30 M SPORT
Is there anyone in Essex UK area who can help me with this refrofit? I have most of the parts already just waiting on the switch.
Also is it dangerous to take the power from the airbag? Could that not make the airbag set off / explode???
      02-23-2018, 03:03 AM   #109
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
You're not taking the power from the airbag, you are just using spare sockets on the airbag connector to give you a means of connecting through the wheel centre(clock spring).
Besides, the airbag has no power. The only time any voltage is applied to the airbag is when the crash systems want to trigger it.
      02-23-2018, 05:51 AM   #110
doughboy
doughboy's Avatar
1545
hi guys,
thanks in advance!
realoem shows the F30 switch has the lead attached.
http://www.realoem.com/bmw/enUS/show...diagId=61_2819
f30, heated, heating, steering, wheel
