04-23-2019, 10:44 AM | #177 | |
Rep 120
04-26-2019, 09:33 PM | #179 |
Rep 17
Ayye! This worked for me. I used enet cable and e-sys to grab my .fsc file. Found the maps I needed (NEXT 2019.2). Code that was generated worked, and maps updated (took forever, but updated).
Thanks very much!! Jagaer If you're still collecting the .fsc files, I can send you mine. Let me know. |
05-01-2019, 05:51 AM | #180 |
Rep 3
Hi, in my navigation system there is the map Europe Route, recently bmw had released the new Europe West Route 2019-2, is it possible to generate the FSC code from the generator?
05-01-2019, 03:21 PM | #181 |
Rep 17
There is a drop down for Europe West Route 2019-2. I'd image with the .FSC file it would generate the code for you.
05-03-2019, 09:34 AM | #182 |
Rep 3
Dear,
I downloaded Europe West Premium 2019-1 I need FSC code for CIC My car VIN is VP71942 Could you send it life time please. Production date 2011.04.09 Thank you very much for your help. |
05-03-2019, 09:51 AM | #184 |
Rep 17
05-07-2019, 05:31 AM | #185 |
Rep 3
Grrrr!
Hello and help please.
I have a 520D last 7 digits of VIN C073231 Build date 22 Sept 2008 – Originally a CCC system. Delivered in Australia in September 2010 I have changed to a CIC with a retrofit system obtained from Latvia several years ago. Everything in car via the CIC works fine BUT not knowing what the original Donor VIN was, I cannot seem to get the 2018 Australian maps to be accepted with the FSC generator. I can download the 1b file without problem and the generator accepts the code, I dutifully select each panel and generate a code. I have tried both the normal and lifetime codes and neither is accepted. I am trying to update the 2014 version premium maps to 2018 premium maps NAVD_000004D6_255_002_159 . The console accepts the map USB and asks for the FSC and this is where it tells me to go away and come back with a good code. Any clues on how I can resolve this issue please? |
05-11-2019, 02:41 PM | #187 |
Rep 8
Hi Jagaer,
Thank's for the program !!! I tried some code with VIN, no luck. I used fsc file, and Lifetime code is OK VIN D210736 / Prod. date 2013.03.11 NBT 0xDE MAP EUROPE NEXT 2019-1 CODE Lifetime JGDD7Y7HPZWCQAFJAD7Q Attached file (delete .txt) Last edited by stecom90; 05-11-2019 at 02:51 PM.. |
05-17-2019, 02:08 PM | #188 |
Rep 3
Hello Jagaer,
I tried some code with VIN, no luck. Road Map North America NEXT 2019-1 and my vin D693809 / Prod. date 2014-09-11 could you help me please? |
05-28-2019, 01:22 AM | #190 |
Rep 3
please help
hello please i need help ,i put usb with map in the car and install maps without asking code fore activation , and couple day after is asking for code!! i red file from bmw f10 with enet and esys and when i try to generate code for nbt next map 2019-1 i have 3 difrent code and every is wrong , please can you help me . PX3SFYTCJZYPWAFJAA4A regular
ECEDEBLDNCIXIAFJAD7A and life time 2OTVQCQPIPCDAAFJAD7Q https://drive.google.com/open?id=1_aLcbi...d2uPqdgOrq this is file WBAXA31060DW63171 THIS IS WIN |
05-28-2019, 04:26 AM | #191 | |
Rep 120
I may be wrong but it could be that you have installed incorrect maps. I have F10 model from 2010 which has S609A Navigation System Professional same as yours. I was told that it is CIC and I updated using Professional maps without issues. |
05-28-2019, 05:19 AM | #192 |
Rep 3
hello 100% sure i have pickure before and after ,,,
https://drive.google.com/open?id=18s...imAGxL8Du3NRAC |
05-28-2019, 05:54 AM | #193 | |
Rep 120
Did you choose CIC or NBT option when generating the code? You should be using NBT. I had used a different FSC code gen. Let me check if I can find you a copy of that. |
05-28-2019, 06:04 AM | #194 | |
Rep 120
05-28-2019, 06:06 AM | #195 |
Rep 30
06-01-2019, 05:40 PM | #196 |
Car Hypochondriac
335
Rep 901
Just tried to install NA 2019-2 and pulled my FSC file from esys, fed it to the generator... Key didn't work. I also tried going by the date, and that didn't work either...
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
06-01-2019, 05:56 PM | #197 |
Car Hypochondriac
335
Rep 901
Per the generator, these are the two codes I should be using:
North America NEXT 2019-2 Non-lifetime 2013.8.29 Build date F478100 BUARG35M3NCO6AFIAA7A Lifetime DKOP2IQGFCUFEAFIAD7Q When I punch these into my nav, it says both are incorrect... how can this be? EDIT: With a different FSC generator, I got this as my lifetime code: KTVX7LXZTNECUAFIAD7A It worked.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 Last edited by Eschmacher; 06-01-2019 at 06:08 PM.. |
06-10-2019, 05:45 AM | #198 |
Rep 1
Help needed
Hi,
I downloaded Road Map Europe EVO 2019-2 I need FSC code for NBT EVO My car VIN is OY23496 I wasn't able to generate valid FSC. Could you send it to me please. Production date 2017-05-23 Thank you very much for your help. |
