05-17-2022, 09:06 AM | #1 |
Rep 116,110
N54Tuning.com - CSF BMW B58/B48 Front Mount Triple-Pass Heat Exchanger W/Rock Guard -
Order Link
https://www.n54tuning.com/csf-bmw-b5...ard-black.html Manufacturer: CSF Description: CSF BMW B58/B48 Front Mount Triple-Pass Heat Exchanger w/Rock Guard - Black Product Name: CSF Heat Exchangers Part #: csf8131B CSF upgraded the inlet/outlet design and improved the core specifications for better air-flow, water-flow, and improved cooling system performance. These updated features result in further lowering Intake Air Temperatures (IATs) of the air-to-water in-manifold charge cooler air cooler system for maximum performance. Ultra-Efficient 42mm 2-Row Core, with CSF’s B-Tube Technology, and 6.5mm Multi-Louvered Fin Height Results in Optimized Airflow Through the Heat Exchanger Core and Into Other Cooling System Components for Maximum Performance of the Entire Cooling System (Especially Critical if Installed in an X-Drive Model with Transmission Oil Cooler Placed in Front of Heat Exchanger) Triple-Pass Flow Design Upgraded Inlet/Outlet Design with New Tapered Entry and Exit Points from End Tanks, Resulting in Optimized Water Flow and Increased Performance (Matches OEM Spec)* Included Detachable Rock Guard OEM CNC Machined Mounting Location Pins and Brackets Direct Plug-and-Play Design, Including CNC Machined “Quick Connect” Inlet/Outlet Water Fittings Includes Hardware Mounting Kit* for Applications That Have a Factory Transmission Oil Cooler Mounted in Front of the Heat Exchanger (X-Drive Models) No Modifications Needed to Install For a More in Depth Look Please Check out the CSF B58 Heat Exchanger Press Release OEM #: 17118741830 & 17118625431 |
07-16-2022, 09:58 AM | #2 |
Rep 116,110
07-29-2022, 10:57 AM | #3 |
Rep 116,110
09-11-2022, 04:39 PM | #5 |
Rep 116,110
09-29-2022, 11:40 AM | #6 |
Rep 116,110
10-30-2022, 07:52 PM | #7 |
Rep 116,110
12-13-2022, 11:57 AM | #8 |
Rep 116,110
02-13-2023, 02:23 PM | #9 |
Rep 116,110
03-08-2023, 07:11 AM | #10 |
Rep 116,110
04-21-2023, 10:10 AM | #11 |
Rep 116,110
06-21-2023, 12:01 PM | #12 |
Rep 116,110
07-10-2023, 10:02 AM | #13 |
Rep 116,110
08-14-2023, 08:03 AM | #14 |
Rep 149
Drives: Alpine white bmw f30 335xi
Do you have these in black available for n55?
09-27-2023, 09:47 AM | #15 |
Rep 116,110
12-11-2023, 09:16 PM | #16 |
Rep 116,110
01-17-2024, 10:50 AM | #17 |
Rep 116,110
