02-27-2014, 09:11 AM | #1 |
Rep 19,982
Washer fluid bottle- designed by an idiot?
Am I the only person that finds the design of the F3x system a bit weird?
The sharp turn at the spout means you have to pour very slowly for it not to spill everywhere! And then because the actual bottle is hidden there is no way to monitor usage and check if it should be done. And then once it is almost full, because you can't see the pipe or neck, you've no real warning of when it's about to overspill! The one good thing is that at least there is an ok place to rest the bottle for the half an hour it takes!
02-27-2014, 09:43 AM | #2 |
Rep 67
I agree - refilled mine last night from one of those 5ltr square plastic bottles you buy from BP stations and the first half a litre went into the engine bay rather than the filler hole.
You just can't get close enough to the hole when the refill bottle is full and the liquid just splashes straight back out from the shallow reservoir before it goes down the pipe into the tank Still, when pulling out from the petrol station and merging back into fast moving dual-carriageway traffic all is forgiven - the torque just makes you forget all your petty niggles....
F31 330d M Sport Tanzanite + heated Black Dakota
Pro Nav/Visibility Pack/Comfort Pack/Harman Kardon/Comfort Access/Adaptive Suspension/Tow Bar etc |
02-27-2014, 09:55 AM | #3 |
Rep 19,982
Glad I'm not alone... still half expecting someone to come along and tell me it's actually brilliant and that I'm doing something wrong!
02-27-2014, 09:56 AM | #4 |
Rep 111
Drives: 2014 BMW 328d/2011 BMW X5d
Well yes it's hard to get to but when you get the washer fluid low warning, I get those gallon bottles and pour one in and always end up using it all, never having a little left over so when the warning light comes on I know I can put in a gallon without overflowing.
02-27-2014, 12:41 PM | #6 |
Rep 764
Yeah, I use a funnel for mine as well. We use a lot of the stuff here up north, so I top it up almost weekly. I wouldn't want to be stuck out driving in the snow and salt with no fluids.
As a side note, we also have an Audi Q5 and the design is the same as for the F30. |
02-27-2014, 12:44 PM | #7 |
Rep 313
On the E90 I had the reservoir absolutely empty on purpose. I added 1l of screenwash and the warning was still there, then added 250ml still warning me but another 250ml warning had gone. The manual says it takes 6l.
02-27-2014, 12:48 PM | #8 |
Rep 19,982
The funnel can help with the spillage somewhat, but not with the crap flow rate. And because of the 90 degree angle right at the top I'm guessing the funnel would be awkward to use, and would probably need to be held.
02-27-2014, 01:03 PM | #9 |
Rep 121
I filled mine for the first time during the week and was thinking the same thing, the 90 degree bend means it takes forever to fill....
02-27-2014, 01:16 PM | #10 |
Rep 15,858
5-series is similar... funnel and care.
Anyone remember the plastic pouch we used to have in cars years back? Takes me back to my Cortina Mk2 GT, held not much more than a pint of washer fluid, needed filling every few days in winter. Makes today's filling an easy task. HighlandPete |
02-27-2014, 02:46 PM | #12 |
Rep 25,113
Agree it's a PITA but always has been on the BMs. Another +1 for funnel use.
My car made front page of Bimmerpost
02-27-2014, 03:00 PM | #13 | |
Rep 3,488
But yes that takes me back. And if I remember correctly they used to puncture very easily too. |
02-27-2014, 03:18 PM | #14 |
Rep 1,089
I'm sure this subject was brought up before. Filling the washer bottle in the F30 has always been a pain without overspilling
I normally fill a small container with diluted screen wash, gentley pour into shallow top & filter. Takes a bit time but saves the spillage all over the engine bay. Not sure on what others do ? I wonder what the BMW service garages do, let it spill & wipe off excess Not aware that the filter can be removed. Never tried it as it seemed to be fixed & i didn't want to force it. |
02-28-2014, 02:55 PM | #15 |
Rep 412
I can't get the funnel to balance in the neck
So I've got a plastic milk bottle cut in half and that works brilliantly!
F06 640D Gran Coupe M Sport+ Alpine White with Black Nappa
Previous: F31 320D M Sport Touring Mineral Grey / Coral Red |
02-28-2014, 04:14 PM | #16 | |
Rep 1,502
Drives: M4 CP SSII/SS
Current: F82 CP SS/SS
02-28-2014, 04:15 PM | #17 | |
Rep 9,709
02-28-2014, 05:33 PM | #19 |
Rep 19,982
That's the best solution I've heard so far anyway... Did you cut a hole to line up with the right angled pipe entrance too?
02-28-2014, 05:34 PM | #20 |
Rep 19,982
The time it takes to fill up would be longer than the time BMW allocate for a service!
03-01-2014, 02:20 AM | #22 | |
Rep 20,651
A mate has a bit of hose stuck on his water bottle works really well but I can't be arsed going that far. |
