07-08-2020, 04:19 AM | #312 |
Rep 10
07-08-2020, 10:48 AM | #313 | |
Rep 2,302
So you can try newer psdzdata or a newer version of E-Sys. If that doesn‘t help you need a newer Launcher. For example, you can currently use Launcher Pro 2.8.2 again. |
07-08-2020, 11:26 AM | #314 | |
Rep 10
which is similar cafd of CAFD_00003C3B_001_007_011,then i can open with ncdcafd tool end see where is what..?? |
07-08-2020, 03:42 PM | #315 | |
Rep 2,302
If you could upload your CAFD_00003C3B i could try to open it with my 3 different launchers and after that i can tell you an advise. |
07-09-2020, 04:29 AM | #316 | |
Rep 10
https://mega.nz/file/pN0DRCjC#5aofuc...vtJlvWsnzRXEAY |
07-09-2020, 03:19 PM | #317 | |
Rep 2,302
Unfortunately I could only test the CAFD with the LauncherPro 2.8.2 and it didn't work there either. I just realized that my LauncherPro 3.7 expired today and therefore I could not test the CAFD with it. |
07-10-2020, 01:58 AM | #318 |
Rep 10
07-10-2020, 02:25 PM | #320 |
Rep 10
07-20-2020, 07:45 PM | #321 |
Rep 266
Hi does anyone know how to reset brake service indicator or any service? Holding the bottom left corner button doesn't seem to work anymore like on the original cluster.
I had 6wb retrofitted on my 2016 f34 a few months ago. Build date 7/2015 |
07-28-2020, 01:24 PM | #322 | |
Rep 14
Thanks |
07-28-2020, 01:26 PM | #323 | |
Rep 14
Thanks |
07-28-2020, 01:28 PM | #324 | |
Rep 14
My car is F30 11/12. Thanks |
07-28-2020, 01:29 PM | #325 | |
Rep 14
I have te same problem. Thanks. |
07-28-2020, 03:12 PM | #326 | |
Rep 14
I have the same problem. Thanks. |
07-28-2020, 04:08 PM | #327 | ||
Rep 15
The problem is that the HUD hardware prior to 07/2013 is different than after this date. The only solution will be swapping the HUD to one produced later, which is a hell of a job (whole dash needs to be removed). Before you could try to flash the DKOMBI somehow to older software which might work with the old HUD. I am still figuring out if this is possible with 6WB |
07-28-2020, 04:11 PM | #328 |
Rep 14
My friends I solved one problem about it . When the car has combox module you need put loop connection on most cable to bypass combox module !!! . Now I just solve the problem of flicker on HUD !!! I believe that will be fdl coding !!!
My friend shawnsheridan can you help us ? |
07-28-2020, 04:14 PM | #329 | |
Rep 14
But thank you for your attention |
07-29-2020, 03:48 AM | #330 | |
Rep 15
Only chance is swapping the HUD to a 2014+ version (the newer the better). |
