12-01-2020, 02:33 PM | #1 |
Rep 7
Best plug & play bulb: Halogen to LED
I currently have the factory halogen headlights with the halogen bulbs. I am looking for a led low beam bulb that doesnt require modification or coding. What is the best option?
12-01-2020, 03:43 PM | #3 | |
Rep 1,217
If your car is an LCI then you will need the mounting clips but, since the bulbs operate at 55w just like stock halogens, they do not require any coding. |
12-01-2020, 04:20 PM | #4 | |
Rep 1,452
12-01-2020, 04:31 PM | #5 | ||
Rep 1,217
12-01-2020, 04:31 PM | #6 |
Rep 16,075
They don't operate at 55w, no LED does, that's advertising BS, and that has nothing to do with the need for coding anyway. You have to code out the cold and warm checks, whether you have canbus harnesses and/or resistors or not. The cold and warm checks will cause the LEDs to periodically blink when they're not on. You don't see it with halogens, because they don't react fast enough, but with LEDs you do.
12-01-2020, 04:40 PM | #7 | |
Rep 1,217
12-01-2020, 05:00 PM | #8 | |
Rep 7
12-01-2020, 05:05 PM | #9 | ||
Rep 1,217
12-01-2020, 05:22 PM | #11 |
Rep 1,217
BlackBetsy1.50 |
12-01-2020, 07:47 PM | #13 |
Rep 500
12-01-2020, 07:55 PM | #14 |
Rep 1,217
I haven't yet been required to take the car in for our CA smog check inspection since I bought the car about 2 years ago. So I don't know for certain. But it seems that our CA smog inspection is only concerned about emissions, readiness, etc.
12-01-2020, 08:44 PM | #16 | |
Rep 500
12-04-2020, 06:00 PM | #17 |
Rep 7
Am I able to use a siccor jack on the front jack points one at a time to get a better access point into my wheel well? OR will this simply rip the side of my car off?
