BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Will 17inch rims clear 345mm rear brembos?
      10-17-2021, 07:38 PM   #1
andrew3series
Drives: BMW 340i xDrive
Anyone have any experience with this? Looking to get forged apex 17x90 et30 squared and wondering if itll clear the 2 piston brembos in the rear? Im on a 340/4pot front and 345mm/2pot rear setup
      10-17-2021, 09:16 PM   #2
johnung
The odds are against a 17" wheel fitting over the rear Brembo calipers.
      10-17-2021, 09:19 PM   #3
Pussiwillow
Drives: Alpine white 2014 335i msport
Someone has done it, however not all 17's are going to fit
I think it's fairly selective wheel options for that.
      10-18-2021, 11:05 PM   #4
andrew3series
Will the arc-8s fit?
      10-25-2021, 03:38 PM   #5
SD Convert
Drives: 2017 430i convertible
Here's a picture of 345MM M-Sport brakes in a factory 18" rim:
https://f30.bimmerpost.com/forums/pi...ictureid=77374
There's quite a bit of space outside the caliper, so SOME 17" rims should fit. Unfortunately, it's close enough that you'll need to individually verify them.
