08-31-2018, 05:08 PM | #1 |
Rep 5,377
P0107 Error: Manifold Absolute Pressure/ Barometric Pressure Circuit Low
Is anyone familiar with this error message? (Please see photo.) Got a check engine light that turned out to be this error message on an F30 N55 engine after charge pipe and intercooler installation. Engine seems to be idling and running well. I was told that this error should clear and the check engine light turn off, as soon as the condition that is causing it goes away. Not sure if that is true.
I checked the connections on the charge pipe, intake, etc and everything appears tight. The wording on the error seems to indicate an air pressure leak somewhere (but it also could be a poorly worded description). Wondering if I should squirt a soapy water solution on air intake and vacuum connections and look for bubbles? Any ideas would be appreciated. Thanks. |
