BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Boost Leak F30 335i
      04-03-2018, 05:02 PM   #1
UpstateSC335i
Drives: 2014 335i
Boost Leak F30 335i
Installed my JB4 Connect tonight and was able to monitor my boost. The JB4 connect was easy to install and the gauge read outs look great on my 7 inch Samsung tablet.
Anyway, I was getting about 11psi on map 2 and 12.5 psi on map 5. I expected to be making more boost and I am worried I have a leak. Current mods are Burger Tuning Intake, Catless DP, Charge pipe. I was running 93 octane. Is this the boost I should expect or do I have an issue?
      04-03-2018, 05:31 PM   #2
Mouse
Drives: 2013F30 335i
Get some logs and send to Terry at BMS. You'll get some help here, but that will yield the best results.
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
      04-03-2018, 06:25 PM   #3
mike@x-ph.com
mike@x-ph.com's Avatar
Datalog and send the results to Burger Tuning
Also double check charge pipe and intercooler for any leaks
https://x-ph.com/sale/
Phone number 702-494-9435
      04-04-2018, 02:31 PM   #4
s2kvee
Drives: 2008 BMW E90 M3
On map 5 I’ve been getting the same results as well.. however in map 2, I’ve seen higher boost readings 14-15psi, and occasionally 18-19psi..
Map2 - 13-15psi (sometimes 18-19psi)
Map5 - 11-13psi
Mods: AFE Cold air intake, catless DP, MPE Exhaust, Charge Pipe, VRSF intercooler
2013 PWG model
91octane California gas
      04-04-2018, 05:16 PM   #5
Dylan86
Dylan86's Avatar
Drives: F15d msport, F22 m235i
More boost doesn't always mean more power. Map 2 spikes a lot, and makes very little timing advance, map5 may feel worse, but in most cases it's smoother power overall.. Just my $.02
      04-04-2018, 10:45 PM   #6
badbread
not good, but bad
Drives: 2013 335i
What do your logs show in terms of actual boost and boost target? Are they close to eachother? Within 1.5 PSI, give or take a bit. If so, there's no boost leak and something else might be going on (fuel quality maybe?)
Your on Map 5 which is JB4's self adjusting map, meaning I think it accounts for things like atmospheric conditions, IAT, other parameters I don't know, etc.
Check out my blog link here:
http://*************/letslog/#boost
See if that helps at all. Post up a link to your log on datazap.me
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube
