BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > WTB - BAVSOUND STAGE 1 and GHOST Subs
      09-11-2019, 02:09 PM   #1
Joeypdx
Drives: 2018 330
Looking for a HiFi compatible BAVSOUND Stage 1 and /or Ghost Sub setup for my 2018 330 with standard HiFi system.
      09-18-2019, 04:15 PM   #2
foveon
Drives: '16 428i GC Carbon Black
I'm selling the Bimmertech amp portion if interested.
      11-05-2019, 10:33 PM   #3
Joeypdx
Drives: 2018 330
Bump - anyone?
      11-08-2019, 11:49 AM   #4
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
I've got the ghost subs, currently installed in GF car but we'll be trading it in a few months. PM me if interested.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      11-09-2019, 11:28 AM   #5
Toad535
Drives: F10 535 MSport
I've got a bavsound for the Harman kardon e90/F10. I think it's compatible, just have some extra speakers. You could confirm by emailing them then let me know if you are interested.
      11-09-2019, 01:20 PM   #6
johnung
I've got the stock H/K system. I just upgraded the underseat subwoofers to Earthquake SWS-8Xi which have better specs. And I added a secondary amp just to power them at 150watts RMS/channel. An AudioControl ACM-2.300. A $50 Technicpnp harness made it simple to wire into the stock system without any cutting or splicing. I could revert to stock in minutes if necessary.
This project was a huge upgrade to the entire audio system. The stock speakers are pretty great, it's really the bass that's lacking. This upgrade fixes all that.
      11-09-2019, 10:39 PM   #7
Joeypdx
Drives: 2018 330
You think I could get by without the amp? They are a heck of a buy compared the bavsound ghost.
      11-20-2019, 12:18 PM   #8
moorty
moorty's Avatar
Drives: 2014 328i
I have both the Stage 1 and the Sub in my hi-fi 328. I also have the amp, which you can do without, but is absolutely amazing in terms of its ability to control the EQ. Subs are great without the amp, but are mindblowing with it...
I was actually just about to list them on this page. Feel free to direct message me and let me know which one(s) you're interested in.
      11-25-2019, 11:10 AM   #9
M Smurf
M Smurf's Avatar
157
Drives: 2013 328i M Sport
I might give this a shot given the prices on these subs! Plug and play install for the most part? The additional amp required in your opinion? Thanks
      11-25-2019, 03:40 PM   #10
johnung
Technicpnp harness makes it plug and play. The secondary amp is required for the subs. Can't just swap the upgraded Earthquake SWS-8Xi subs in without the secondary amp because of their 2-ohm rating and power requirements.
The requirements also mean that there aren't easy substitutions. I searched like crazy and couldn't find anything that met every requirement like the AudioControl ACM-2.300.
For the stock H/K amplifier outputs through the Technicpnp harness you need to connect to an amp or LOC that can handle 40 volt speaker level inputs. Many have marketing materials that make it sound like they will work but can't really handle 40 volts! At the other end of the chain the secondary amplifier needs to be able to output two channels of 150 watt RMS per channel into 2-ohms each.
The AudioControl ACM-2.300 is a combo LOC & amplifier in one with the perfect specs for this project along with small size to make mounting easy without taking up valuable space.
I collected a lot of detail and photos as I did this project so I'm writing it all up to share.
Hope this helps!
draggy29.00
      12-05-2019, 08:21 AM   #11
Joeypdx
Drives: 2018 330
Since I have the HiFi system and not HK is the Audiocontrol still the best choice? I can attest that there isn't enough power to drive the Earthquake subs - I installed them and clearly need the amp. I just don't want to spend a fortune on a sub - not that the Audiocontrol is horrendously priced...
Hope this helps!
      12-05-2019, 09:13 AM   #12
johnung
Hope this helps!
Yes, you still need the AudioControl amp. The amp requirement is a requirement of the Earthquake SWS-8Xi needing the power. It's not a function at all of the system/amp driving the rest of your car's speakers. So HiFi or H/K doesn't matter to the subs.
Think of it like two separate audio systems with one amp playing only your tweeter & midrange speakers, and the new secondary amp playing only your two underseat subwoofers.
Assuming you got the Earthquake SWS-8Xi (2 ohms) and not the Earthquake SWS-8X (4 ohms). The AudioControl ACM-2.300 puts out 2 channels of 150 watts RMS and each go into 2 ohms. 150 watts is the ideal amp for the Earthquake subs. Larger isn't better because a larger amp would just have to adjust its gain down to not overpower and distort the subs. Smaller amps may not take advantage of the Earthquake design that sound so good in those tiny BMW underseat subwoofer cabinets.
I'm really impressed with the quality and specs of the AudioControl, especially to have a high quality built-in LOC that can handle 40 volt speaker level inputs. And it's so small too!
Hope this helps!
