11-17-2017, 04:06 AM | #1 |
No 55mph
1622
Rep 8,476
F32 to M4 Side Mirrors - Anyone Do This?
Looking to switch out my F32 side mirrors for the M4 versions, as I like the design better + looking for a change
Back in my E92 days this was a simple swap & PnP as long as you got mirrors with correct options I would assume this would still be the case for F32 to M4 swap - just checking to make sure - anyone have experience doing this? And if so, will M3 mirrors also fit the bill? And NO, I don't want to simply use cheap fleabay mirror covers to attach to my F32 mirrors to 'simulate' M4 mirrors - do it the right way or stay home
11-17-2017, 06:45 AM | #2 | |
Rep 1,953
Drives: 2013 328i xDrive
11-17-2017, 12:27 PM | #3 |
No 55mph
1622
Rep 8,476
Checked out realoem - M3 mirrors are all different P/N from M4 - which I pretty much assumed was gonna be the case. E92 vs E90 M3 mirrors were different & not interchangeable - it was the mounting stud pattern that was different...
So now I know I must go with M4 mirrors. Not gonna go with new, I'll shop around & find some in good shape used - not in any great hurry Just wanted to make sure that mounting pattern for M4 was same as F32 & that wire connectors are they same (on E92 there were 2 versions - (1) 3 pin & (1) 5 pin) so you had to know what your were getting) Find it hard to believe no one in F3x crowd has done this swap - it was a favorite for E9x
11-17-2017, 01:23 PM | #4 | |
Rep 1,953
11-18-2017, 07:48 PM | #5 | |
Rep 306
No, M3 and M4 mirrors have different attachment to body. Look at the windshield frame. You cannot mix. Simple swap if you have exact same optional equipment as the F8x donor. Lots of luck with that! There are like 287 or so combinations. And I guess you’ve priced out new parts separately? Depending on car options, the MSRP is close to $4k for the pair....more if you add in MP Carbon Fiber Covers. And yes I’ve done swap from F80 to F30. |
11-19-2017, 01:25 PM | #6 |
Rep 26
It looks like BMW offers official retrofit kits, but if you are looking at buying used it probably won't help you.
The links are to a german website. https://www.leebmann24.de/bmw-ersatz...=03&bt=03_0760 https://www.leebmann24.de/bmw-ersatz...=03&bt=03_4003 |
11-19-2017, 08:19 PM | #7 | |
Rep 306
It’s a list of replacement parts for a M82 Mirror repair, such as can be found on realoem.com. You can verify this by putting in the last 7 of your F32 VIN and it will tell you that the parts are not compatible. |
11-20-2017, 12:40 PM | #8 | |
Rep 26
On a side note, as I copy pasted "Fahrzeugausstattung", my first try left me with an all caps text "FAHRZEUGAUSSTATTUNG"... German really is the angriest looking language in writing |
11-20-2017, 12:53 PM | #9 | |
Rep 26
BMW 428i Coupé F32 ab Baujahr 07/2013 Modellcode 3N31 Motor N20 Getriebe N Lenkung L Then "Alle Kategorien" and "Nachrüstung / Umrüstung / Zubehör". Selecting "Nachrüstung M Aussenspiegel" and entering the last 7 digits of the VIN for my old F32 which is "K327211" and I get confirmation for the parts which fits. It is correct that I do not get confirmation for part 01 which is the complete mirror, but I get all the sub components 02, 03, 04, 05 and 06. |
11-20-2017, 01:07 PM | #10 | |
Rep 306
11-21-2017, 01:41 AM | #11 |
Schmollbraten
12512
Rep 1,985
You could install M4 OEM side mirrors w/o any problems, just remove the door cover inside, the tweeter loudspeaker cover, remove the 3 bolts and exchange the mirrors.
Important is, that the substitutes would have the same (or more) features than your present installed. E.g. if you have surround view and the new ones hadnt, you have to code this out. But: You wouldnt switch to lousy 3 series M3 mirrors, no?
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
02-27-2018, 11:32 AM | #12 | |
Rep 343
Drives: 2018 M4 SMB 6MT
http://f30.bimmerpost.com/forums/sho....php?t=1467733 |
1QuikWS61621.50 |
02-27-2018, 06:46 PM | #13 | |
No 55mph
1622
Rep 8,476
They are in excellent condition & I got a great price Stay tuned for the installed pics after I add a little more flair with some custom mirror caps that are unique
Mousejunior122.00 |
05-01-2018, 03:00 PM | #14 |
No 55mph
1622
Rep 8,476
Some quik installed pics with the new NWC Honeycomb CF Covers:
05-02-2018, 01:33 PM | #15 | |
Rep 166
Nachrüstung litteraly means retrofit. If it was a replacementpart it would be ersatzteile. Also, leebmann is an official bmw/mini dealer. Leebmann24 is just another site of them where they offer oem parts a little cheaper than the official bmw prices. (This is his dealership website: http://www.bmw-leebmann.de/de/home/) Salesafter is another example of an official dealer with an extra site to purchase oem parts outside of the dealership. According to realoem there is an official retrofit for these mirrors: http://www.realoem.com/bmw/enUS/show...diagId=03_0760 On topic: nice retrofit, i love cf but i’m not a big fan of the honeycomb. (Didn’t even know it existed) Edit: just noticed the date...oops. |
1QuikWS61621.50 |
05-02-2018, 01:54 PM | #16 |
No 55mph
1622
Rep 8,476
No problem - I actually just updated this post yesterday with some pics
If you wait for the right deal this can be done fairly cheaply I paid $738 shipped for the correct M4 mirrors from a forum member for all my options (actually they have 1 more option than I needed in the Sideview cameras, but no biggie they just aren't used) That's with the Euro Heated/Autodim Aspheric glass both sides. Mirrors are in perfect condition without a mark on them. The CF covers are custom made by NWC using OEM mirror caps, laminated with the CF, vacuum bagged, multiple coats of UV clear polished between each I like to have items on my car that no one else in my area has. I already had the OEM CF caps on my F32 mirrors, nothing special. So I decided to get something unique. Plus the price of them was less than the cost of OEM CF covers & that includes cost of base OEM covers
05-02-2018, 02:09 PM | #17 |
Rep 166
Really, laminated? Nice fitment! I have some carbonfiber cloth, resin and loads of clearcoat. I was thinking of laminating my covers but wasn’t sure how that would look fitment wise. Maybe I should try it, I have spare covers anyway... not sure how it will turn out since I haven’t got the tools for vacuumbagging.
It definintely is a unique look, never saw it before. Kuddo’s to you for doing something else. |
1QuikWS61621.50 |
05-02-2018, 02:14 PM | #18 |
No 55mph
1622
Rep 8,476
Yup, and best thing is they have 100% perfect fitment as they are made from OEM cores
The vacuum bagging is almost a must to get a perfect job - especially when part has multiple curves going on - the weave on these is perfect with no distortion. He can (and does) cover any part you want & he does deal with regular 2x2 or 1x1 twill CF
