12-31-2017, 01:41 PM | #1 |
Rep 1,499
VIDEO: DIY CTS Turbo FMIC & FTP Charge Pipe Installation
Hopefully this helps some of you guys out!!
terryd5150507.00 BrockNotBrooke2.50 Bimmer_pnoy16.50 Kennedy2816.50 akgambino271.50 jimmy8904563.00 badbread332.50 ceedawg467.50 thug10820.50 BMW DIY Guy3075.00 |
12-31-2017, 01:49 PM | #2 |
Rep 965
Drives: 2016 F36 435x MSport
sweet thanks for the vid. The only recommendation i have is do NOT let the MAP just dangle in your engine bay. That bad boy is incredibly expensive (MAP is on the charge pipe, MAF is on the intake). Much safer to remove and put aside safely to prevent damage.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
JaredG_F301106.00 thug10820.50 |
12-31-2017, 01:57 PM | #3 |
Rep 1,499
Yeah I ended up disconnecting it after I removed it from the CP. It was easier that way for me.
01-18-2018, 03:51 PM | #5 |
Rep 10
Thanks for posting this. I have been looking for a good tutorial, seems easiest to just do both at the same time. Hopefully getting this done in the next month or so. How long did the total process take?
01-18-2018, 05:06 PM | #6 |
Rep 1,499
From the time I put the car on jack stands to when I brought it down took about 6 hours but that was also managing the camera and includes the VRSF downpipe installation. Just the FMIC and CP probably took half of that.
03-14-2018, 07:25 PM | #7 |
Rep 1,348
lol Not for nothing but after seeing this I felt bad for you man and myself. I think I am going to take the front bumper off.
2k15 335i Msport xdrive 6spd
03-14-2018, 07:32 PM | #8 |
Rep 1,206
I did my fmic. I notice absolutely zero in performance gain. I said it once I'll say it again. These cars don't need upgraded ic unless u track them or live out in Cali and can run the mountains for thirty mins.
I am sure logs will show a small benefit but who cares. Save your money |
akgambino271.50 |
03-14-2018, 08:43 PM | #10 | |
Rep 529
At the same time, my understanding is that if you are running a proper tune with proper ignition timing and safely/reliably increasing the boost as much as 2x stock levels the stock intercooler simply cant keep up and even after one pull to redline heat soak will rob you of the additional power your new levels of boost are providing. People who bash the stock intercooler for being trash are sort of wrong... bmw didn't engineer it for 15+ psi of boost to run through it, if you wanna do multiple back to back runs in warm weather with the car bone stock I doubt you have any greater issue of heat soak and power loss than any other modern turbocharged vehicle on the road. I have a cts FMIC sitting here waiting to be installed, I didn't buy it for the gains I bought it to make sure that the gains I paid for with an expensive dme tune would be ensured.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
the dope steez404.00 ceedawg467.50 |
03-15-2018, 06:18 AM | #12 |
Rep 1,348
Beg to differ with you but Not on ALL cars simply not true especially with BMW air to air fmic's. That is so general. You keep saying This! Once you raise the boost or big tirbo, the efficiency of the stock FMIC starts going down the toilet. FACTS
03-15-2018, 07:21 AM | #13 | |
Rep 1,499
Logs show otherwise. With my CTS Turbo FMIC I'm seeing IATs about 10-15 degrees above ambient. With the stock FMIC I could easily see temps 40-50 degress above ambient. On an 80 degree day the aftermarket IC will keep your DME from pulling timing and robbing you of power.
ceedawg467.50 |
03-15-2018, 08:50 AM | #14 |
Rep 1,348
Yeah and reliability if you want to stay stock. That is also the reason why BMW runs only 4 to 9 psi on this car. They realized that going water to air was more efficient overall in making more power reliably. Hello 340i,M3,M4,M5,M6 all using air to water!
03-15-2018, 10:28 AM | #15 | |
Rep 1,206
It seems like its a common mod for people that are staying bolt on their dailys. I am here to say they are wasting money. The other point i made is that factory ICs have improved dramatically since the mid 90s(i think you own a car that fits this bill as do i). Its not as required as it once was. We owned cars with ICs that were half the size of a cereal box and 75% plastic. I think a lot of people drink the coolaid. It just isnt the case anymore. It used to be considered a big power adder. IT is not on these cars. I agree logs will show some improvement. But not worth the cost. If you live in a warm region and want an IC for reliability purposes thats one thing. But for me i wish i didnt spend the money. Last edited by matty088; 03-15-2018 at 10:40 AM.. |
03-15-2018, 10:59 AM | #16 | |
Rep 1,499
To each his own. I know for me it was worthwhile as I tend to drive pretty aggressively and like to hit mountain/canyon roads frequently. Just a couple pulls to over 6,000 RPM can heat soak the stock IC pretty quick. You can def see the difference on a dyno as well with back to back pulls.
ceedawg467.50 |
03-15-2018, 01:22 PM | #17 | |
Rep 1,348
Again ,any car that is running stock boost with Bolton’s then there is no added benefit. You can even actually lose power in that case running a bigger more efficient FMIC. However once the boost is raised or we go bigger turbo you will only benefit then from using an aftermarket FMIC especially on a F3x car period. Most guys who go fbo either get a tune or piggy back anyway for additional power. What gives you additional power more so than any mod even if you were stock? Raising the boost past stock levels then making it wise to purchase a more efficient FMIC due to increased heat,airflow and power all from increasing the pressure and airflow(boost) It’s physics! PS the stock FMIC on the F3X cars I would not consider to be a big FMIC. It’s been engineered to run low boost with the little turbo that is on the car for reliability.
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 03-15-2018 at 01:27 PM.. |
akgambino271.50 |
03-15-2018, 01:29 PM | #18 | |
Rep 1,348
03-15-2018, 05:21 PM | #19 | |
Rep 707
Logs will show drastic delta's all day. A solid aftermarket intercooler can be had for sub $500. |
ceedawg467.50 |
03-15-2018, 07:10 PM | #20 | ||
Rep 5,457
Drives: F30
03-27-2018, 04:52 PM | #21 |
Rep 1,348
Anything is better than stock thats for sure. But quality depends on how much you want to spend.
03-27-2018, 04:57 PM | #22 |
Rep 1,348
JaredG_F301106.00 |
