03-29-2018, 02:14 PM | #23 |
A family of bimmers
2747
Rep 7,742
great video. what would you say was your total time to install? Im looking to tackle this in an evening or a morning on the weekend. Ive got vrsf FMIC and CP to do.
03-29-2018, 03:21 PM | #24 |
Rep 808
It does make it much easier to do each when you do both at once - you should be able to do both in less than 3 hours. Get a buddy to help support the weight of the IC and to help thread the CP up (one of you push from the bottom, one twist an pull from the top) and you could do it even quicker.
wdeerfield2746.50 |
03-29-2018, 03:32 PM | #25 |
Rep 1,499
Took me about 4 hours by myself with moving the camera around for all the shots. You should be able to do it in 2 with a buddy, 3 by yourself.
wdeerfield2746.50 |
03-29-2018, 04:14 PM | #26 | |
Rep 1,348
The charge pipe disconnecting part seems like the biggest PITA.
2k15 335i Msport xdrive 6spd
03-29-2018, 09:11 PM | #27 | ||
Rep 808
akgambino271.50 |
03-29-2018, 09:13 PM | #28 |
Rep 1,348
ahh of course!,
03-29-2018, 10:23 PM | #29 | |
Rep 647
03-30-2018, 07:36 AM | #30 |
Rep 1,499
I'm also counting in time for unpacking parts, organizing tools, getting the car up on ramps then jacking up, removing the bottom cover, putting bottom cover back on, etc. Yes the biggest PITA is getting the old CP out. Manhandling the new IC is a bit of a bear if you don't have a helper.
wdeerfield2746.50 the dope steez404.00 |
03-30-2018, 09:43 PM | #31 | |
Rep 1,206
03-30-2018, 11:27 PM | #32 | ||
Rep 647
*image is distorted, may try google drive to post better res* Last edited by Drpoomanchu; 03-30-2018 at 11:32 PM.. |
03-31-2018, 05:30 AM | #34 | ||
Rep 1,348
Drop da mic moment!!!Boom! Thanks for the charts
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 03-31-2018 at 05:47 AM.. |
03-31-2018, 07:13 PM | #35 | |
Rep 1,206
U are on crack rock if you think any ic is going to drop temps 15 degrees over a two or three gear run. Something is faulty with his analysis. An obvious fault is that he is wot for basically half a gear. Its meaningless. I have looked at dozens of logs (including my own with a top of the line fmic) and not one is lowering iat like that. I mean shit. Not even th manufactures are claiming this. U really need to get your head out of the sand. Just Bc someone says something it doesn’t make it right. Also when I first read his post I thought he meant drop below ambient. THAT is what I meant by my physics comment. However now that I see what he is saying he’s still wrong and his tests are faulty. Just go in any mhd or bm3 or jb4 thread and read for yourself. Enough with this nonsense U will get a dip of a few degrees when u go wot which is true for any ic. The stock one as well. . You get a rush of fast moving air through. but as you heat that air up with your turbo it’s going to rise and rise fast. Please wake up. And look at the plethora of logs on this forum or just use common sense. Last edited by matty088; 03-31-2018 at 07:30 PM.. |
03-31-2018, 07:35 PM | #36 |
Rep 1,206
And your wrong. The job of an ic isn’t to drop iat. Bc only a complete ignoramus would make that claim. The job of a fmic is to slow the rate at which iat climb as your turbo heats the air. I might have to start ignoring you. All your stuff is out of left field.
03-31-2018, 07:48 PM | #37 | |
Rep 1,206
However as you stay into wot and boost you’re going to heat up that air very quickly. If you want a scientific test to measure the performance of a fmic id say go into wot at 2500 rpms in 3rd and get into atleast the middle of 6th (assuming you are auto). You’ll see temps rising for sure. However the ic that shows the least amount of rise is your winner. Of course on a road course it’s a far different set up principles. But we all have street cars so we will look at that scenario. I’d be happy to discuss this with you once you get that done or I can share my logs with you. However ceedawg isn’t invited. I am Joking ceedawg. But yea. You’re nuts. Here are more scientific tests http://www.bootmod3.net/log?id=5aac4e54d10b43251c8572b1 http://www.bootmod3.net/log?id=5aac4e1fd10b43251c8572af Last edited by matty088; 03-31-2018 at 08:00 PM.. |
03-31-2018, 08:24 PM | #39 |
Rep 1,348
Do you know how to read!! I said the purpose of an IC is to cool the charge air under boost so as a result you will also have cooler denser air intake temperatures which also lowers IATs! We both speak English right? You should put me on ignore because you don't read properly and your interpretations of what many folks say here is always incorrect!
03-31-2018, 08:25 PM | #40 |
Rep 1,348
Its definitely one good way to cool but not the only way and that is not the only use or benefit.
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 03-31-2018 at 08:34 PM.. |
03-31-2018, 08:33 PM | #41 | ||
Rep 647
03-31-2018, 08:38 PM | #42 | |
Rep 1,206
Anyways what I said is right. An intercooler isn’t dropping temps unless you make a flawed test where u go wot for a couple thousand Rpms and in which case iat would drop for any ic. If you go meth then yes you are dropping temps. But an ic, nope |
03-31-2018, 08:49 PM | #43 | ||
Rep 647
ceedawg467.50 |
04-02-2018, 08:14 AM | #44 |
Rep 1,499
OK let's talk physics. Your statement regarding an "ic can't drop iat" is completely false. In fact, the whole purpose of the IC is to drop IAT. An IC is just a simple heat exchanger. Hot air running through the charged air piping is cooled via ambient air (which is cooler) running past the fins of the intercooler. A more efficient heat exchanger will reduce the charged air temps lower than a less efficient heat exchanger. This is simple thermodynamics.
https://en.wikipedia.org/wiki/Intercooler
ceedawg467.50 Drpoomanchu307.50 |
