03-16-2018, 07:19 PM | #1 |
Rep 1,206
Question on boost
Why does boost build so slow on these cars? It seems like boost steadily increases as Rpms rise and as you go thru the gears. It seems like we don't see "full" boost until 5th gear. Why just have full boost the entire time. I could see limiting first gear for traction purposes. But after that what's the arguement to limit boost?
03-18-2018, 12:04 PM | #2 | |
Lofty
3458
Rep 849
F30 335 (FBO and BM3 OG)
991.2 C2 Range Rover Sport Diesel I4 M50 (coming soon) |
03-18-2018, 01:49 PM | #3 |
Rep 115,980
With the JB4 you can get peak TQ pretty quick.. It does take some RPM to spool the turbo so a turbo car will always need some RPM to get going..
03-18-2018, 07:59 PM | #4 | |
Rep 1,206
Yea in my experience if you run say 15 psi. U may get there in 1500 Rpms but once there u are there. I don't know the boosts behavior in the n55 seems odd to me. Takes forever to get 15psi. Why not have it in second gear. Why do u needto wait to 5th. What's the arguement there? |
03-19-2018, 02:46 PM | #7 |
Rep 5,372
1) Turbos require load and in the lower gears, there isn't enough load in order to generate full boost. Most turbos will not see full boost in 1st or 2nd gear. It's just not possible.
2) BMW tunes there turbos to deliver a more naturally aspirated type power delivery. They intentionally make it so that boost increases as the rpms increase (to a point). They're basically trying to make the I6 turbos behave like a small displacement, decent revving V8 where power is progressive and linear and torque is flat. When you add most any tune or piggyback, the device alters this linear power delivery and adds a substantial amount of power below 6000rpms, often times making that peak power is realized in the lower 5,000 rpms range vs the lower 6,000rpms for stock.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
03-19-2018, 07:14 PM | #8 | |
Rep 1,206
