03-28-2018, 09:44 AM | #23 |
Rep 1,348
Get any answers?
2k15 335i Msport xdrive 6spd
03-28-2018, 10:17 AM | #24 |
Rep 808
No, but I haven't submitted a support ticket on this latest map yet. I want to try the 91 map first, also my car is also scheduled in for fuel pump replacement next week.
If neither of those things work I'm going to check/re-gap plugs and then I'm all out of ideas! |
03-28-2018, 10:49 AM | #25 | |
Rep 2,639
The boost spikes isn't too dangerous so I wouldn't worry, I had it all the time on PWG V2-V3, it normally does that after you shift.
FSociety3812.50 |
03-28-2018, 10:58 AM | #26 | |
Rep 808
03-28-2018, 08:03 PM | #27 |
Rep 808
Just logged some new pulls on the 91 tune. I got my new 93 map from Dzenan so I'll be trying that out next once my LPFP is replaced.
http://www.bootmod3.net/log?id=5abc3433d10b4374deee200d http://www.bootmod3.net/log?id=5abc3448d10b4374deee2011 http://www.bootmod3.net/log?id=5abc344ad10b4374deee2012 Car feels a little smoother on the 91, as in no hiccups when accelerating in 4th or 5th from 2500 rpm. Still got some negative timing and a few knocks here and there. Mostly continuing to post so I can come back to these logs later and compare easily Last edited by the dope steez; 03-28-2018 at 08:23 PM.. |
akgambino271.50 |
03-28-2018, 08:18 PM | #28 | |
Rep 1,206
03-28-2018, 08:22 PM | #29 |
Rep 1,206
My car seems to run way less boost than yours and I am on 93? I guessing this has to do with timing. I can't understand why on this platform they don't target boost and the car makes whatbit makes at said boost.
So while I run much less boost but my timing is way higher I wonder who makes more power. |
03-28-2018, 08:26 PM | #30 | ||
Rep 808
The funny thing was when I called the service dept, I just said I had a 2013 335i, and the nice young lady said yes you need the recall, when do you want to book it in? Didn't ask for VIN, didn't check if it was done earlier. It was kind of strange I thought, but I'll take it! Quote:
I found this article on timing/knock informative: http://stratifiedauto.com/blog/under...oboost-engine/ |
akgambino271.50 |
03-29-2018, 12:18 AM | #32 | |
Rep 2,639
If you have high timing but low boost, its the same as the above only, you can add more boost to even it out. You want to look for 14-15 psi on 91 octane with 5+ deg timing. And 16psi on 93 octane with 5+ deg timing. Everyone thinks the more boost you run the better, but thats is not the case, you need a good balance between boost and timing. (I would say 30% boost 70% timing in terms of importance) Here's an example with my log on PWG HSTG2 91OCT map v3 http://www.bootmod3.net/log?id=5a7eeb7fd10b430955a2cf90
03-29-2018, 08:41 AM | #33 | |
Rep 1,206
03-29-2018, 09:27 AM | #34 | |
Rep 2,639
http://www.bootmod3.net/log?id=59b077add10b43473418a139
FSociety3812.50 |
03-29-2018, 09:37 AM | #35 | |
Rep 1,206
03-29-2018, 09:40 AM | #36 |
Rep 1,206
mine ewg 93 oct stage2
http://www.bootmod3.net/log?id=5aac4e54d10b43251c8572b1 http://www.bootmod3.net/log?id=5aac4e1fd10b43251c8572af look similar. u are targeting more boost and for some reason i have low fuel PSI |
03-29-2018, 09:43 AM | #37 | |
Rep 2,639
03-29-2018, 11:16 AM | #40 | |
Rep 808
Are you running stock plugs or the NGKs recommended by PTF? |
03-29-2018, 11:30 AM | #41 | |
Rep 1,206
plugs are stock. |
the dope steez404.00 |
