11-25-2019, 06:17 AM | #89 | |
Rep 398
The MSI Trident has a marginally better CPU (but can't be overclocked) Arguably the Fusion Pro is the much better PC. Looking at the spec shown, I would bump the PSU up to 650W for that little bit more headroom. Depending on the gaming they will do I would bump the cooling up a bit as if it gets hot with an air cooler it is going to get loud. One of the Corsair AIO water coolers would be great for this. Last edited by Kyuuseishu; 11-25-2019 at 06:24 AM.. |
11-25-2019, 06:47 AM | #90 | |
440i Gran Coupe, Auto
877
Rep 1,295
How is it games consoles have a life cycle of say 5 or so years and the games are pretty decent and yet with PC gaming the machines are constantly evolving? Are the games that much better on high end gaming PC's than on consoles?
Z4M40i Black Sapphire
11-25-2019, 09:02 AM | #91 | |
Rep 1,475
Also, if the OP is wanting something out of the box, I'm presuming that overclocking isn't going to be on the cards. In short, yes. The hardware capabilities of a PC can outstrip a console multiple fold as you've got the scope for expansion, upgrading and turning the effects up to eleventy stupid. The console games are limited by the hardware as the games have been designed to work with one particular spec.
F20MAW73876.50 |
11-26-2019, 06:32 AM | #92 | ||
Rep 32,881
F20MAW73876.50 |
11-26-2019, 01:05 PM | #93 |
Barge driver
8656
Rep 12,425
When you go to a console gaming show like E3 in LA, all the big publishers have vast stands with rows and rows of LED panels showcasing the latest game with controllers so you can play, all sat on top of a plinth, in the plinth (out of sight) it's a high end PC not a console.
But as a dedicated machine a console is a very good piece of kit at a very reasonable price and meets the needs of the vast number of gamers especially the X and 4 pro.
730d/Z4C
F20MAW73876.50 |
11-26-2019, 02:34 PM | #94 | |
Rep 1,264
PC's always push the boundaries in relation to graphics, CPU and memory. As a result there are multiple games on a PC that simply wouldn't work on a console. The Total War series is a classic example. Likewise Virtual reality on a PC is far superior to VR on a PS4. That said you can enter a world of pain in relation to constantly upgrading a PC to cope with games..no worries with a console. |
11-28-2019, 06:52 AM | #95 |
877
Rep 1,295
I have ended up going £500 over budget and ordering this one.
https://www.pcspecialist.co.uk/configure-review/345/
11-28-2019, 11:43 AM | #96 | |
Rep 3,490
By the way there is nothing wrong with the 1080ti if you want to save your self a shed load of money and still have pretty much the same performance. |
F20MAW73876.50 |
11-28-2019, 03:48 PM | #97 |
Rep 398
Well as long as the games are on the M2 then it should be fine. Partially agree with the memory, I'm still running 16gb and haven't run into memory issues as of yet. Not that many games that will soak up 16gb worth of memory.
11-28-2019, 05:19 PM | #98 | ||
Rep 32,881
11-29-2019, 03:17 AM | #99 |
Rep 3,490
11-29-2019, 03:19 AM | #100 |
Rep 32,881
I don't think higher than 3000mhz ram will make any real world difference, I tried overclocking my 3000mhz ram and it didn't make any noticeable difference in benchmarks anyway.
12-02-2019, 02:56 PM | #102 | |
Rep 398
https://www.scan.co.uk/blackfriday |
12-02-2019, 03:00 PM | #103 |
Rep 311
I wanted to spend around £80 and get the best 24 inch possible with speakers built in preferably. I don't see the point in going all out as he's only 6 and probably wouldn't even notice the difference
12-02-2019, 03:18 PM | #104 | |
Rep 398
This is the best 24 inch with speakers I can find currently. Best without them is this one. |
12-08-2019, 08:15 AM | #105 |
877
Rep 1,295
The pc I have ordered has a GEFORCE RTX 2070 Graphics card which has the following display port connections; HDMI, USB Type-C, DVI-DL.
His Samsung TV/Monitor has both HDMI and the DVI-DL connections. I need to purchase a cable. I take it would be best to purchase a HDMI cable?
12-08-2019, 08:25 AM | #106 | |
Rep 398
F20MAW73876.50 |
12-15-2019, 03:47 PM | #107 |
Rep 311
I've finally managed to find the time to get the computer up and running. I've put 4 fans in I moved the stock fan to the front and put 2 coloured ones in the top and one in the back. The front and back ones draw cool air in and the top ones extract this. Is this the correct setup or would you recommend a different way?
12-15-2019, 03:53 PM | #108 | |
Rep 398
12-15-2019, 04:01 PM | #109 | |
Rep 1,264
Thats all you will need as the graphics card and processor will also have fans. If you have an Uber system then you might need more fans but otherwise just more noise. Download this programme (everyone worth their salt uses it ) connect your front and rear fans up and monitor the temps https://www.cpuid.com/softwares/hwmonitor.html |
12-18-2019, 04:10 PM | #110 |
Rep 311
It is quite noisy with all fans running to be honest. With the fan on the front you can't see any lights as the casings in the way that's why I swapped it and put the stick at the front then coloured at the back so you could see the coloured fan through the glass window. I'll swap the fan at the back round to exhaust the heat and I may disconnect the 2 top fans from spinning and just have them lighting up so take the noise down abit
