BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Codding headlight module
      02-12-2020, 09:12 PM   #1
Edtech1300
Drives: 2017 BMW 330xi
I bought a totaled 2017 BMW 330xi, I have fallen in love with the car and almost complete with the repairs. I had to replace one of the LED light control modules. I replaced the unit with the exact same model number but the item did ship from another country (ebay)
link to item purchased (https://www.ebay.com/c/19014145082)
I have listed the issues I'm having below
Side markers are not illuminating
High beams do not stay lit (3 seconds maybe)
Sometimes lights dont work at all
The dash indicates low and high beam malfunction
Below is a list of DTCs from my Bluedriver scanner.
-805B12 FLE_R: Low-beam headlight 1: Voltage outside of tolerance range
-805B2B FLE_R: High beam: Voltage outside of tolerance range
-805B3A FLE_R: Lowbeam headlight: Function defective
-805E63 High beam headlight/headlight flasher: Function defective
My question is does this sound like codding issues or a faulty control module.
I could see the issue with the marker light being coding related but the list of faults have me leaning towards bad module. If it could be coding is it possible to backup the codding from the working headlight module and dump it to the used ebay module?
Any help in the right direction would be appreciated! I'm not afraid to learn the codding actually looking forward to it for some other mods I have seen. I already own the ENET cable.
Thank you.
      02-13-2020, 01:20 AM   #2
RuleNormaliai
RuleNormaliai's Avatar
20
Drives: F31 320d EfficientDynamics
You have to code your new control modules.
If you want i can help remotely, or you can do it by your self with esys.
