BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Start Logo in Instrument Cluster Catagory
      02-12-2020, 09:34 PM   #1
BassMasta808
Drives: 2018 330i
I coded the start logo to be M Performance but after a reboot I didn't see any difference on the instrument cluster. What exactly is the start logo?
      02-13-2020, 01:26 AM   #2
RuleNormaliai
RuleNormaliai's Avatar
20
Drives: F31 320d EfficientDynamics
1. Which cluster do you have?
2. Cluster start logo shows when you enter your car but not turn on ignition, and when you turn off your ignition. (Before coding it had to be BMW)
If you have standard instrument cluster you are not able to fo mpm.
If it does not show up on 6wa cluster - you have to flash it to the latest istep, as some does have mpm logo and some does not,mine showed up only after flashing.
      02-13-2020, 08:03 AM   #3
BassMasta808
Drives: 2018 330i
I have 2018 330i M-Sport if that helps. Here's my cluster. Not sure which one it is.
      02-13-2020, 11:38 AM   #4
RuleNormaliai
20
It is standard cluster, you cannot change logo in it.
