BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bimmercode app iOS/Android
      02-04-2020, 12:48 PM   #551
Matlor
Drives: 330d xdrive f30
Originally Posted by 90SLOWE View Post
I hadn't tried receiving calls since activating EBT, but mine doesn't work either. Did you try the short version from the thread or the full BimmerCode suggestion?
I haven't tried connecting 2 phones at the same time yet, but I'll take EBT Over the receive call button any day so I'll probably leave it as is. Do let me know if you figure it out
Hi bud, got this all working, not through bimmercode but once you go into Bluetooth select options beside the I drive controller and the settings are in there.
      02-16-2020, 11:31 AM   #552
DRD_Dragos
DRD_Dragos's Avatar
Drives: 2012 F30 320D
Another adapter that works flawlessly with Bimmercode, at lest on IOS and an Iphone 6 on latest firmware is this. Make sure you get the black one and WiFi version (Vgate ICar2) and don't be tempted to get Icar 3 or pro or anything else. I never had a disconnect or trouble connecting with this one.
https://www.amazon.co.uk/Vgate-Scann.../dp/B01CG0XWDI
https://www.amazon.com/Vgate-Elm327-.../dp/B06XGFTZ5R
      02-19-2020, 10:45 AM   #553
hldfreitas
Drives: bmw 320d
Hi. Can someone please help me. I bougth a 10.25inch screen, and when I try to use bimmercode to change the resolution, it doesn't apear the "display size resolution" option, Does anyone know what is the problem??
      02-19-2020, 11:19 AM   #554
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I have that and it will not work with my Android pad Bimmercode. I had to go to a Veepeak, this one:
https://www.amazon.co.uk/Veepeak-OBD...YRNEK6SW8&th=1
      02-19-2020, 04:03 PM   #555
Rameez_209
Drives: BMW 320D F30
Can someone help bimmercode for bigger size resolution CIC headunit
Hi, I'm new to this form. about half an hour a go i did learn alot about bimmercode and coded my car aswell.
I have an android screen which is 10.25" it works perfect but the BMW idrive system has small screen it doesn't look good. can someone help me with what code I need to increase the screen resolution size (display size).
i have a bmw f30 320d auto 2014 and the head unit is CIC (on bimmercode it display hu_cic) it's got built in satnav.
The code i found is for NBT unit
Screen Swap then code code:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
But for my unit I don"t have the display size resolution.
can anyone help me with the code how to make the screen size bigger for CIC head unit
Thank you
      02-20-2020, 10:52 AM   #556
hrgiger
Drives: E92 325d
hey guys, had a good read through this thread and managed to code what i wanted with the great advice on here, and usinf OBD adapter and bimmercode.
one thing im struggling with, and im not sure its possible on my car, is to be able to start the car without having to nsert the key fob into the dash..
can anyone point me in the right direction on bimmercode app, or if its even possible on my car ?
i have always been able to remove the key from the dash once i start and stop the car once, but never start without putting the fob in once to start with...
thanks
si
      02-20-2020, 12:18 PM   #557
sdbmwcoding
Drives: BMW M3
thanks
si
No you need comfort access for that
      02-20-2020, 12:26 PM   #558
hrgiger
Drives: E92 325d
ok, thnaks for the info, i can stop looking now..
much obliged.. ;-)
      02-24-2020, 02:26 PM   #559
hsk1610
Drives: 2013 328i xDrive
sorry if this has been asked before- can you code back to default on Bimmercode the individual modules or do I have to connect my laptop and use Esys?
      02-28-2020, 01:15 PM   #560
DadzBmer_N2o
DadzBmer_N2o's Avatar
Drives: F30 320ix
I hope this works the Vgate ICar2 one for my Iphone 7+ or Ipad Pro Gen 1. I tried using the Enet Cable + Apple Ethernet w/USB + Apple USB Camera to Lighting adaptor. I got an error message from BimmerCode below.
I had the right connections, turned my phone on Airplane mode, Do Not Disturb settings and Wi-Fi turned off. Seatbelt on, Accessory mode on as well.
Holy crap, i think i am so stupid, i didn't know u have to purchase the full version for like $32 ish, i was watching a current vid of Jon at his YT channel: ThicF30 coding his new M2 F87...
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o
      02-28-2020, 02:42 PM   #561
Billfitz
Billfitz's Avatar
Do you have an F30? If so update your garage, if not you're in the wrong forum. F30 never require putting the fob in the dash. For that matter there's no place in the dash to put it.
You can.
      03-04-2020, 02:52 PM   #562
wilbur_the_goose
Drives: 2018 330ix Gran Turismo
Hi - long time Bimmercode user, new car for me. I have an '18 F34, and Active Sound Design isn't listed as a module. Is this because the F34 doesn't have ASD, or do I need to look elsewhere?
      03-04-2020, 03:56 PM   #563
Billfitz
Billfitz's Avatar
If you don't have it listed in your decoded VIN you probably don't have it. I don't have it. If I did I'd be coding it off.
      03-13-2020, 06:44 PM   #564
radeohedca
Drives: 2007 328i 6-spd NAVI
Originally Posted by DieselSport View Post
Wow , bimmercode has endless coding options in Expert Mode. I just coded my seat to move back when i open my door, and the roll front again when i start the car. Didnt even know i had this option.
3000 SM Global > Einausstuegshilfe. Once here just change from nicht aktiv to Modus_FA_SLV.
And thats it.
This didn't work on my 2013 320i. In fact the Modus_FA_SLV option did not show up when connected to my car (it does in Demo Mode). I tried setting it to 0x03 in Custom Value but that didn't work.
Could there be a setting elsewhere that needs to be set correctly to allow this to be changed ?
Thanks.
      03-14-2020, 07:17 AM   #565
radicalrev
Indonesia
Drives: F30 320i
Can anyone confirm if Vgate Icar2 still actually works with the latest version in IOS?
I ask because in Indonesia we only have the Vgate ic2 available, however bimmercode website does NOT recommend Vgate anymore.
I want to make sure before purchasing.
      03-14-2020, 07:41 AM   #566
Tatts4278
Drives: 2013 f30 328i x drive
I have the vgate 4.0 and it works with bimmer code on iOS. last I knew bimmercode didnt work on android but once you pay on iOS for it you can not transfer it to android.
stay healthy
      03-15-2020, 07:27 AM   #567
radicalrev
Indonesia
Drives: F30 320i
Is it the Vgate Icar Pro? Do you use the bluetooth or wifi version on IOS?
      03-17-2020, 03:18 AM   #568
Tatts4278
it's the icar pro 4.0 and I use it with bluetooth on iOS for bimmercode and bimmerlink. I also use it on bluetooth for android with my silverado for regular obd2 scans.
stay healthy
      03-17-2020, 07:36 PM   #569
radicalrev
Indonesia
Drives: F30 320i
Thank you very much for the confirmation
      03-20-2020, 04:55 AM   #570
gippy
Drives: F32 440i, pre-LCI, w/MPPSK
does anyone know if there is an option to get the windows fully 100% down in comfort open?
i had a look through all the various menu options but couldn't find it.
so at the moment when i double-tap the unlock button on the key fob, the window rolls down about ...i dunno...60% of the way.
thanks
      04-02-2020, 06:21 PM   #571
MRii328i
MRii328i's Avatar
36
Drives: 2013 328i sportline
Yes it does work. I bought my car 2 weeks ago and have coded many things. Most importantly auto start/stop always off and I enabled the sport transmission. Everything else I did is cool, but these really enhanced my driving experience. I used the android version.
      04-03-2020, 08:16 AM   #572
MRii328i
MRii328i's Avatar
36
I used vgate icar pro 4.0. Wifi off. Airplane mode on. Music bluetooth adapter unplugged. It came with this disclaimer, that I haven't seen posted anywhere yet.
