BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > No audio after NBT retrofit
      10-31-2018, 10:55 AM   #1
Bayliss02
Drives: BMW 2013 F34
Hi All,
Hopefully someone may be able to help. I have completed my NBT retorfit this morning into my 2013 F34. I came from HU_entry and had DAB radio.
Installed the new screen and NBT, however there is no sound on either radio or when I call someone I can't hear anything (so not just an issue with radio). USB and reversing camera all works ok which is positive.
I've connected everything properly into the NBT, does anyone have any ideas on what could be the issue? I haven't moved any wires in the quadlock, am I meant to?
Thanks, any help greatly appreciated!
      10-31-2018, 11:23 AM   #2
SuhaibD98
Drives: BMW F30 M Sport 2014
Originally Posted by Bayliss02 View Post
Hi All,
Same thing happend to me
That NBT has either come from a car that has an amplifier or upgraded sound system and needs to be coded in to accept your system
Or it could be the other way round, you may have an amplifier but that nbt may have come from a stock car
It just needs to be coded accordingly
      10-31-2018, 11:48 AM   #3
atzebmw
Drives: BMW 335XD F30 LCI
That is probably too simple thought.
Of course it has to be coded.
      10-31-2018, 01:15 PM   #4
Bayliss02
Thanks for replying SuhaibD98, will look into the coding and see if that does the job
      10-31-2018, 01:17 PM   #5
Bayliss02
Ok thanks will have a look into it
      10-31-2018, 02:20 PM   #6
SuhaibD98
It should solve your issue 100%! it's happend to loads of people and they've done the same thing im guessing everything else works fine?
Let me know how it goes!
      11-01-2018, 10:12 PM   #7
midnightf30
midnightf30's Avatar
Drives: 2014 F30 328i BASE
2014 BMW 328i  [0.00]
With the NBT retrofit if you have hifi audio l remember reading somewhere that the amp trigger wire would need to be tapped so it would turn on with the car or something of the sort.
      11-01-2018, 10:58 PM   #8
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
Send me the VIN of your car and the donor car and I should be able to make a file that can change the amp for you. You will need a working USB port on the NBT
obert1252.50
      11-02-2018, 11:28 AM   #9
Bayliss02
Have PM'd you Steve
Cheers
      02-11-2020, 05:49 PM   #10
M135imike
Drives: F20 m135i
Any chance you can help me?
Apologies for resurrection of this post.
I've recently fitted nbt in my f20, it has an amp in the boot (left hand side).
But I only get sound when my car engine is running, I get no sound if I'm sat with just the ignition turned on, screen etc powers up fine, though.
      02-13-2020, 08:50 AM   #11
azatos612
Drives: E60
Hello! Did you solved your problem?
      02-14-2020, 01:26 AM   #12
M135imike
Drives: F20 m135i
I have! Was a pretty easy solution when I knew what it was 😂
      02-16-2020, 07:05 AM   #13
azatos612
Drives: E60
How you did? I have same problem (I retrofitted f10 nbt with base audio system, sound only when engine started&#128532
      02-17-2020, 04:29 AM   #14
M135imike
Drives: F20 m135i
You need a 'add a fuse' tap into small black wire on amp wire, then to fuse box
      02-18-2020, 04:18 AM   #15
azatos612
Drives: E60
Thanks, but I donít have amplifier.( base system)
