11-10-2019, 07:22 PM | #1 |
Rep 25
Fortune Auto 500 Series Coilovers, 900 miles review 340i
I've had 3 other sets of Fortune Auto 500 Series coilovers in previous vehicles and always had a good experience with them so I decided to stay away from the common KW's and Bilsteins products and went to what I have good experience with. I added the radial bearings to this set.
Build quality - same build quality as my previous 3 sets, I like the fact that top hats are included. Installation - There are no installation instructions available, so I had to source the internet instructions and torque specs. Thanks youtube and google! I've installed various suspension components in various vehicles so I wasn't deter but it still would've been nice to have been provided torque specs. Install is easier compared to others because front and rear top hats are included and assembled out of the box. It saved me time not having to remove the OEM top hats to install on the coilovers BUT while installing the fronts, the mounting points didn't fully fill the mounting holes, not sure if this changes suspension geometry but I am concerned under heavy load the mounting points will move... I'm sure that's not something I want to happen. The mounting point for the OEM strut bar also didn't align AT ALL, I have to force the strut bar mount hole into the top hate mounting point, I've contacted Fortune Auto about this but I guess they're in SEMA this week so they haven't gotten back to me yet. User experience The Good - good ride quality - no squeaks - lots of adjustability for price - easier install The bad - lack of installation instructions - PITA rear height adjustment - does not go low enough, although it'll do for now The included documents states all 500 series damping is set at full soft, so I just wanted to try to a firmer setting (8 clicks), while on the fronts you turn the knob clockwise to firm and counter clockwise to soft... but while I was adjusting the rear I turn clockwise assuming that it is at full soft but turning clockwise 3 clicks it stopped, sooo I went back 3 clicks and turned counter clockwise 8 clicks. This has me worried because I'm not sure if I'm at 8 clicks to firm or 8 clicks to soft!! And again Fortune Auto was at SEMA this week so I can't get any answers yet. Rear ride adjustment is more of a PITA compared to other brands because every time you adjust the rear spring height you also have to adjust the damper height. Don't buy these coilovers if you want to have a slammed look. Lowest ride height in the rear will leave no gap between the tire and fender, while you can set the front ride height perches all the way down to match the rear it is not recommended by Fortune Auto as it needs at least 1" in the lower perch to maintain proper dampening. Right now i have about 2 finger gap between tire and fender, which I'm ok with for now because I'm attending HPDE events and don't want to worry about fenders. I still 1/2" lower to go in the front. The car feels more planted, ride quality is as good as OEM but I will be messing around with the dampening setting. Going over speed bumps requires some finesse. Conclusion - With concerns of the strut bar mount not aligning and the top hat mounts not filling the mount holes, the PITA rear height adjustment, and the lack of customer support (really, EVERYONE went to SEMA?) has me looking to get another set of coilovers that require OEM top hats for proper fitment, it'll ease my mind! Will have updates. Hope this helps someone. 11/15/19 Ride quality - 600 miles with dampening set to 13 clicks to hard. The ride quality is good definitely more firm than OEM but it’s easy to live with. Bumps get absorbed relatively well but big digs and humps be ready to feel it. Last edited by NimbusGarage; 11-16-2019 at 01:16 AM.. |
11-10-2019, 09:56 PM | #2 |
Rep 3,539
Thanks for sharing. Did you use their recommended spring rates, or spec your own?
Also, don't they provide dyno plots of their builds? If you have them, mind sharing? Fortune Auto has their "Broadway Static" line if you want to go super low.
11-10-2019, 11:02 PM | #3 | |
Rep 25
Now that you mentioned it, my other sets came with dyno plots but I don’t remember seeing it for this one. Not looking to go super low... at least not yet haha |
11-11-2019, 11:37 AM | #5 | |
Rep 3,539
11-11-2019, 01:31 PM | #6 |
Rep 681
It looks like those coils are made for the 3 bolt tops. I would check with them to see if they make a 5 bolt compatible top mount since your car is setup for the 5 bolt tops. I think the change from 3 to 5 bolt happened in late 2013 or something.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
11-11-2019, 03:17 PM | #8 | |
Rep 25
I've also brought this up with Fortune Auto and awaiting an answer |
11-12-2019, 10:28 PM | #10 | |
Rep 928
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
11-12-2019, 11:05 PM | #11 |
Rep 1,934
Definitely need some photos. Or measure the fender to ground height.
11-12-2019, 11:38 PM | #12 |
Rep 3,539
Personally I'd pick 5k front and 16k rear, or 4k front and either 14 or 13k rear.
11-12-2019, 11:54 PM | #14 |
Rep 3,539
To maintain a higher rear ride frequency than front that settles the car faster. 280lbs/in is far from soft. The 16k, 159N/mm, 895lbs/in springs only equate to 310in/lbs at the rear wheels due to the motion ratio.
11-13-2019, 10:32 AM | #15 | |
Rep 928
11-15-2019, 11:27 AM | #16 |
Rep 25
Front - I can lower 1/2” more Rear - I can lower 1” more Last edited by NimbusGarage; 11-15-2019 at 11:34 AM.. |
11-15-2019, 04:07 PM | #17 |
Rep 1,934
I think you've sold me. I'll be picking up a set this winter.
These look to fall in between all the regular options and Street Comfort variants, while still being on the performant side as far as the damping profiles. Which is exactly what I was looking for. I'll be rolling the dice on them fitting since I am Xdrive. Since a few other brands do mount in the front without much of an issue, and the shock body is adjustable I shouldn't expect any problems.
11-16-2019, 02:50 AM | #18 | |
Rep 25
11-16-2019, 11:57 AM | #19 | |
Rep 205
Drives: 14 F30 335i xDrive
But if you can wait, then you could get shocks of the appropriate length for xDrive. That way you can set the ride height where you want and you'll be within the most efficient range of the shock, so it will perform better. Also you'll have more suspension travel. This is especially import if you live in an area with any amount of bad roads. |
11-16-2019, 12:58 PM | #20 |
Rep 928
You went with default spring rates? Are you happy with the rates or wished you got another rate? I'm thinking 8k front 14k rear?
11-16-2019, 04:07 PM | #21 | ||
Rep 1,934
11-16-2019, 07:37 PM | #22 | |||
Rep 205
