02-09-2020, 02:30 PM | #1 |
Rep 67
Changing engine mounts, OEM vs Corteco
Anyone changed engine mounts? I'm thinking of the Corteco, they're half the price. I'm not searching for sportier performance or anything, just mounts that are cheaper than the OEM if they're as good as them,
Here is the link of mine in realoem https://www.realoem.com/bmw/enUS/par...BMW-320i&mg=22 And part numbers are as follows: Engine mount, left 12211685941304 Engine mount, right 122116859414 Transmission bearing 22316796617 , Total of all four mount , two engine and two transmission are 300$ , the Corteco would cost half on esctuning Last edited by GOLDENDUSt86; 02-09-2020 at 02:31 PM.. Reason: Typo mistakes |
02-09-2020, 05:08 PM | #3 |
Rep 5,210
i changed mounts recently and bought coretco. interestingly they had the bmw emblem in them which someone had tried to partially score off. so one and the same.
02-10-2020, 03:30 PM | #4 |
Rep 891
Happens a lot with these OEM supplier parts, especially ones that are cast like the mounts or suspension components. My F80 Tension Struts had the M logos buzzed off.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
02-11-2020, 05:07 AM | #5 |
Rep 67
02-11-2020, 08:07 PM | #6 | |
Rep 1,934
02-12-2020, 06:38 AM | #7 | |
Rep 5,210
The car is silent now bar when it hits sharp bumps(when there is a thunk at the mount area) which is because i have a b8 sporty shock with stock i would get mount area rattle even on irregular road surfaces like a tapping noise which i don't now. |
GOLDENDUSt8622.50 |
