01-10-2020, 01:37 PM | #1695 |
Rep 268
This is a question. If you hit a big pot hole what happens to the tire, wheel and car being so low ? It seems that it will just stop the car with no space. Am I missing something ?
01-10-2020, 02:30 PM | #1696 | |
Cheapskate
4445
Rep 4,993
That being said, high siding on a crest is possible and scraping happens. My jack pucks are chewed up along with the air dams under my bumper. But so what |
01-13-2020, 02:46 AM | #1697 |
Rep 115
Been stalking this thread for over 6 months looking over fitments, tire sizes, coilovers etc. and finally decided to put everything together... Wanted to say thanks to everyone in here for the amazing info, welcome to my newly lowered 4 series! Went with ST coilovers and OEM 437M's with M2 fitment for tires (245/265). Better pictures to come, cheers!
01-13-2020, 06:33 AM | #1698 | |
Cheapskate
4445
Rep 4,993
01-13-2020, 12:25 PM | #1699 | ||
Rep 115
01-22-2020, 02:10 AM | #1701 |
Rep 837
437M
225/35 & 255/35 7mm spacer front & 5mm spacer rear Max negative rear camber Last edited by jeremyuhh; 02-03-2020 at 05:10 PM.. |
01-22-2020, 05:42 AM | #1702 |
Cheapskate
4445
Rep 4,993
Toonez87ls9.50 |
01-23-2020, 02:36 PM | #1703 |
Rep 115
01-30-2020, 12:00 AM | #1704 |
Rep 51
not slammed or "stance" but best i could do with an xdrive without busting an axle (learned the hard way) sitting on bc's 18x9.5 30 wrapped in 255/45 all round
01-30-2020, 05:30 PM | #1707 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
02-05-2020, 10:37 AM | #1708 | |
Rep 92
1. Only if you go over 35/245 for tire...then maybe 2. Not bad at all. 3. How are the roads where you live 4. Should cost anywhere from 750 - 1k 5. You'll be about 3-4 inches from the ground if you do |
02-05-2020, 03:11 PM | #1709 |
Cheapskate
4445
Rep 4,993
Amarphoolka144.00 Toonez87ls9.50 |
02-19-2020, 06:24 AM | #1711 |
Cheapskate
4445
Rep 4,993
Not sure why this looks so murky.
02-20-2020, 12:48 PM | #1712 | |
Rep 68
https://f30.bimmerpost.com/forums/sh...postcount=1217 |
F36GC_NYC159.50 |
02-21-2020, 11:41 AM | #1713 |
Rep 32
Looking for some advice....
Car is a 2015 430D Coupe. Front: Current Setup is: 8J x 19” Offset 36 Tires: 225/40/19 New Setup is : 8.5J X 20" Offset of 25 (Japan Racing JR23 in Hyper Silver) Tires are 245/35/20" Rear: Current Setup is: 8.5J x 19” Offset 47 Tires: 255/35/19 New Setup is : 10.J X 20" Offset of 38 (Japan Racing JR23 in Hyper Silver) Tires are 275/35/20" Is all the above correct? Willtheyfit.com says a 28.1mm outward poke, sounds a lot for the rear?? Thanks in advance....didn't realise this Offset stuff would be so hard. Don't want any rubbing as it's a daily. |
02-21-2020, 01:02 PM | #1714 | |
Rep 500
Drives: BMW 330e F30 M-sport
You will definitely be in trouble in the rear if you lower the car. May be fine if you are stock height. Would definitely recommend going with 275/30R20 (not 35). Maybe even consider 265/30R20 if you are planning on lowering the car and don't want to risk having to roll fenders.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
kern4174445.00 |
02-21-2020, 01:28 PM | #1715 | |
Cheapskate
4445
Rep 4,993
In front et25 with a 245 tire will not fit on our cars. I recommend at least 235/30 or 235/35 In the rear it's way too tall. You need a 275/25 or 275/30. If it's x-drive, then move to an equal-diameter 265 tire. |
hybris204.50 |
02-21-2020, 01:53 PM | #1716 | ||
Rep 32
Thanks loads for the replies. My heads been spinning a little with all the different sizes lol! I was going to purchase KW V1 Coilovers for the car to obtain the perfect ride height, but am so nervous about spending the best part of £3000/$4000 on a setup if it's not correctly fitting. I'd be totally gutted. So taking that into consideration, the fitment of KW V1s would you suggest a slightly less aggressive Offset? I'd like my car to look like the following.... https://www.google.com/url?sa=i&url=...AAAAAdAAAAABAD Any advice, again is appreciated....i'm trigger happy so quick replies are great!!! Thanks G |
aggressive, f30, low, slammed, stance |
