BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > FTP charge + boost pipe fitment Intercooler
      07-14-2023, 08:07 AM   #1
Nizzell
Nizzell's Avatar
Netherlands
35
Drives: BMW F36 435i Xdrive
Is it normal that the fitment is quit loose intercooler <-> chargepipe and the same for the boostpipe ?
Checked youtube but nobody is pre fitting the charge and boost pipe with the intercooler before installing
https://www.veed.io/view/ba5c7e82-df...panel=showcase
      07-14-2023, 12:08 PM   #2
Info@mad-us.com
Info@mad-us.com's Avatar
3589
Drives: bmw
That does look pretty loose. If the o'ring doesn't seal you are going to get a boost leak.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
5% OFF Code "BimmerPost" Email: info@mad-us.com
Nizzell34.50
      07-14-2023, 02:43 PM   #3
thejeremyman9
thejeremyman9's Avatar
4495
Drives: 2015 BMW 335i
I vaguely recall that even with larger orings i had some play when test fitting on the floor. IF in doubt just go up in oring size. https://f30.bimmerpost.com/forums/sh....php?t=1659611
Nizzell34.50
      07-15-2023, 10:10 AM   #4
Nizzell
Nizzell's Avatar
Netherlands
35
Tnx, will order some o rings, just 2 be sure
      07-16-2023, 10:07 AM   #5
XutvJet
XutvJet's Avatar
6321
Drives: 2011 Cayman Base, 2018 M2
This is why BMW and every other manufactuer uses plastic. And no, it's not an issue on the charge pipe/IC side as we've NEVER heard of a failure at this connection point on the stock charge pipe. Plastic has some flexibility and will fit tighter.
My FTP charge pipe was slightly loose on my Wagner intercooler and over time and 1000s of miles of driving, I could reach under the charge pipe/IC connection and feel oil residual which indicates not a fully tight seal. There is no major leak as there is no sound and WG duty cycles are fine. I would imagine most every metal charge pipe has this issue, most just don't know it. I just ended up taking 2" wide heavy duty electrical tape and wrapping it around the connection. Been fine for the last 3 years.
I do plan to buy the revised OEM charge pipe with the far more robust CP to throttle body connection. I like the OEM CP for fitment and also lack of heat soaking.
      07-17-2023, 12:08 AM   #6
n55david
n55david's Avatar
2020 BMW X4M   [10.00]
2017 BMW m240i xDrive   [10.00]
2015 X3 x35i  [10.00]
I was running 22psi for tens of thousands of miles while racing and never had any of the issues that you describe.. you had an issue 😆
The oem plastic pipes are garbage and the "revised" one is garbage and still breaks and flows like shit.
2017 m240i xDrive 10.40@132.87mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      07-17-2023, 01:42 AM   #7
Nizzell
Nizzell's Avatar
Netherlands
35
I emailed the shop were i bought the charge + boost pipe. Showed them the video, they say it is normal it is ok...
I emailed FTP themself and showed them the video
They responded " Hello sir Yes, that is normal After sealing and fitting, there will be no air leakage. Don't worry, we had all done smoke testing "
So i asked them again, but it is allready sealed, you know for sure it is ok?
and then they replied
hello
Iam also a BMW owner
i know what bmw wants
We are confident in our products
And there is a warranty~
please check our video
when the smoke fills the intercooler
1:05~1:29
      07-17-2023, 12:15 PM   #8
thejeremyman9
4495
hello
1:05~1:29
That smoke test means nothing if it wasn't pressurized to ~20psi. Anyways, what you showed does appear to be normal and is probably fine.
      07-17-2023, 12:29 PM   #9
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [9.75]
2009 Honda Civic  [0.00]
Go buy Evolution Racewerks piping and intercooler. Stuff fits nice and snug.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      07-27-2023, 09:46 AM   #10
Nizzell
Nizzell's Avatar
Netherlands
35
Installed and tested. Until now no leaks
      07-28-2023, 10:24 AM   #11
mike@x-ph.com
mike@x-ph.com's Avatar
Keep us updated
https://x-ph.com/sale/
Phone number 702-494-9435
      07-28-2023, 03:41 PM   #12
Info@mad-us.com
3589
Drives: bmw
Good to hear! If you were closer I would of sent you one of ours to compare.
- Click Here
      01-27-2025, 05:17 PM   #13
4corsa
Drives: 435xi
Does the MAD Charge Pipe and 5" HD Intercooler have a more snug connection?
Could you upload a video showing that?
      01-28-2025, 12:18 PM   #14
Info@mad-us.com
3589
Drives: bmw
Our xi and non xi charge pipes are different.
Im looking for a xi car if you want to test the charge pipe for us.
- Click Here
