BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > HPFP - 2 bars over - Thoughts anyone? Is this normal?
      01-29-2025, 06:52 PM   #1
shervi
Drives: BMW F20 M135i
So I have been struggling to figure out why my long term fuel trims(LTFT) have been sustained at 30% more fuel. It turns out my hpfp is pushing 2 bars higher pressure across the rev range.
My question is this. As anyone else had an issues with the hpfp over pressurizing, or over fueling. The car is a N55 M135i 2014 with 127k km on the clock. Is the hpfp on its way out? Should I be changing it? I mean, don't we want the higher pressure, especially seeing that I have a map on the car (bootmod3). I just changed the injector profile to Nostrum stage 2 to compensate for the higher fuel input, and everything is working out well at the moment. Just not sure if I should keep it this way, or get the fuel pump changed. I mean is this a good thing or not? lol
Datalogs for confirmation
https://www.bootmod3.net/log?id=665b...62d16a7f179256
https://www.bootmod3.net/log?id=665b...62d16a7f179257
https://www.bootmod3.net/log?id=665b...62d16a7f179258
      01-29-2025, 06:59 PM   #2
shervi
Also, just speaking to my mechanic, he says 2 bars over should be ok for these cars?
      01-31-2025, 03:47 PM   #3
-Eidos
@lbb_kev
553
Drives: 2018 BMW M2 (LBB)
https://www.bootmod3.net/log?id=665be8664c62d16a7f179256
https://www.bootmod3.net/log?id=665be8a44c62d16a7f179257
https://www.bootmod3.net/log?id=665be8d14c62d16a7f179258
I might be out of date with my BM3 naming knowledge but it looks like the DME is removing fuel based on your LTFT and STFT?
If the Nostrum Stage 2 config (highly recommend not running this config without the injectors btw) is helping then maybe you have some leaky injectors.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      01-31-2025, 06:43 PM   #4
n55david
n55david's Avatar
2020 BMW X4M   [10.00]
2017 BMW m240i xDrive   [10.00]
2015 X3 x35i  [10.00]
Uhm..
If you don't have the nostrum injectors.. change it the fuck back 😆 🤣
Also, you have serious throttle closures. Take a log with the correct injectors setting and post it.
What mods and what map are you using?
2017 m240i xDrive 10.40@132.87mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-04-2025, 01:40 AM   #5
shervi
Originally Posted by n55david View Post
Uhm..
This is with he car just idling. On the stock injector and stock hpfp profile.
https://www.bootmod3.net/log?id=67c5...cad113a347dda7
Just a stage 2 bootmod3 map, decatted and an AFE momentum intake. If I put the old one back, which I have tried before the overfuelling goes down by 15%
In the past we have put a new DME (old one was fried). Everything was working well until one day about a year later this thing popped up.
The car has a new
pre throttle map sensor
Maf Sensor
Fuel rail pressure sensor
Pre and Post O2 sensor
NEw Valve cover
New coil and injectors ( spark plugs changed as well to 1 stop colder)
Both vanos solenoids
If I remove the oil cap the fuel trims go back to normal. So I just changed the pcv valve in case by some miracle it had broken down.
Could anyone post there car at idle, so I can compare logs? I am really confused here.
fuel dme, fuel trims, hpfp, ltft, m135i, n55, stft
