BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Pure600
      01-31-2025, 12:26 PM   #1
F30_ry
F30_ry's Avatar
Drives: 2013 F30 335i
Pure600
Anyone familiar with the Pure600 on a F30 with a pwg setup. What mods do I need to have around it to support it and keep it reliable? Lastly what power range am I looking at with simple supporting mods. Would love an opinion. Thanks!
      01-31-2025, 01:00 PM   #2
mike@x-ph.com
mike@x-ph.com's Avatar
intercooler, charge pipe, boost pipe, inlet, intake and a high flow downpipe
they are not mandatory but highly recommended to maximize air flow and keep your turbo happy
https://x-ph.com/sale/
Phone number 702-494-9435
F30_ry0.00
      01-31-2025, 01:06 PM   #3
F30_ry
F30_ry's Avatar
Thanks for the reply! So far that's what I have on the car. Now, as far as fueling, would you recommend changing anything? I run E30 since I'm on stock fueling still.
      01-31-2025, 01:59 PM   #4
mike@x-ph.com
i recommend you check with your tuner and tell him your goals, they will let you know if they can get you there with stock fueling or if you need an ugprade
      01-31-2025, 06:45 PM   #5
n55david
n55david's Avatar
2020 BMW X4M   [10.00]
2017 BMW m240i xDrive   [10.00]
2015 X3 x35i  [10.00]
Wouldn't hurt to upgrade the hpfp.. see what your tuner wants to do.
2017 m240i xDrive 10.40@132.87mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      02-01-2025, 05:51 PM   #6
AmuroRay
AmuroRay's Avatar
3286
Drives: M235i
All this plus a diverter valve. If you need brand specifics let us know.
n55david1442.00
      02-03-2025, 01:35 PM   #7
mike@x-ph.com
yes! completely forgot about the upgraded diverter valve
n55david1442.00
      02-13-2025, 06:51 PM   #8
yupetc
Drives: 2015 X535i
You should just get in touch with Mike at X-PH, give him a call. He's an wealth of good info and pretty much the whole spectrum of parts you might need, you can source it directly from him. Price is good, too. Don't falter yourself mistakenly with so much dis-information through the web and end up with Chineseum stuff and regret later.
2017 540i - MHD2+, VRSF DP, TU Pump
2015 X535i - CP Pistons, Manley Rods, Irox coated bearings, Cometic head gasket, Wagner head studs, M2 crankshaft, MILVs VRSF charge Pipe, Wagner FMIC PURE500 turbo, MHD2+ VRSF DP, B58 HPFP UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
      02-14-2025, 02:34 PM   #9
mike@x-ph.com
Thank you
      02-28-2025, 01:23 AM   #10
Pisancho
Drives: BMW 640i
Do you think a retune is required if running an upgraded fmic? I got a hybrid turbo done and tuned with the stock one and not sure if there is gains to be made retuning with the VSRF 7.5" installed now.
      02-28-2025, 12:24 PM   #11
mike@x-ph.com
same answer since you asked the question on another thread
not sure you will get any power by retuning, you would need a charge pipe and downpipe then retune for more power
      03-04-2025, 04:08 AM   #12
Pisancho
Drives: BMW 640i
Thanks for the reply. I guess i will leave it as is. I already have a DP and CP.
