BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Weird Thermostat Issue
      02-06-2025, 10:23 PM   #23
KingBehrens
Drives: 2014 F30 335i
Originally Posted by KingBehrens View Post
I will, hoping to get it done this Sunday as it’s supposed to be nice out. Might be a bit though since I’ll be doing the oil filter housing gaskets, the Mickey Mouse flange, cleaning out coolant reservoir, and changing out thermostats again just in case. But shouldn’t be too bad, I’ll definitely let you know if my problem ends up fixing itself after that
Update, for me personally it did not fix my issue. Still have a stuck open thermostat code. Will dive into it deeper next Monday. But the job was pretty straightforward. I will say e-torx (10) holding in the cooler are kinda hard to get to with removing the fender liner. But who knows it might work for you, anyways, good luck!
      02-08-2025, 05:05 PM   #24
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by blakekald View Post
I haven't really looked at my coolant level (and if its ever low I get a pretty in your face warning about it via the idrive), but is this really something that can cause the issue I'm having
Is the TStat getting power?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
