06-30-2020, 02:39 PM | #67 |
![]() ![]() 4496
Rep 7,753
Thanks everyone for the input. It sounds like its probably nothing serious or impending failure lol. Will probably just check it again in 5-10k miles or every oil change.
I bumped another thread recently about a potential oil pan gasket leak, and i am most likely going into the dealer for that soon since i have about 1.5 months left on my CPO warranty. Going to mention this at the same time and see what they say, but i suspect they will just say its normal. |
NYOreo2321.50 |
07-09-2020, 02:24 PM | #68 |
Respect My Authoritah
![]() 371
Rep 875
I finally had a non-90 degree day here and decided to install the tensioner kit. My jiggle is completely gone. I effed up part of the install though and while trying to remove the pin from the tensioner, turned it the wrong way and broke part of the cast / bent the pin. There was still enough of the cast to hold the pin when I re-installed, so I figure this is more of a convenience for installing the kit and not necessary when removing the belt.
Check out the picture. Anyone think this is important? Please learn from my mistake! It might be time to cut back on the gym.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
07-25-2020, 01:47 PM | #69 |
![]() ![]() 22
Rep 68
Sorry for the bump
But lots of great info thanks guys. I actually just finished an oil change up yesterday on my '14 335 at 74k miles I noticed the same juggle and sound during idle under the hood. Consensus in the forum seems to say that this normal and is a quick and cheap enough job to just do at your own leisure. Here is my car as of yesterday I'll just probably wait until next oil change and replace for the hell of it. |
07-26-2020, 11:46 AM | #70 | |
![]() ![]() 4496
Rep 7,753
NYOreo2321.50 |
07-27-2020, 10:50 AM | #71 |
![]() 371
Rep 875
Checked my tensioner today, and it's jiggling again.
07-27-2020, 11:35 AM | #72 |
![]() ![]() 4496
Rep 7,753
Mine looks the same as my "before" video i posted previously, even after BMW said they replaced it. I think some amount of wiggle is normal. Its only if you have excessive play or its making noise its an issue.
It's just strange since some of the "after" videos i saw showed it rock solid. |
Korvo371.00 |
07-27-2020, 11:36 AM | #73 |
![]() ![]() ![]() ![]() 178
Rep 643
is the amplitude of jiggle any different? this is why i haven't done mine, just seems this is by design.
M235i rwd 6mt
07-27-2020, 12:06 PM | #74 |
![]() 371
Rep 875
It seems exactly the same. I took a video right after install and it was completely smooth. I guess it "broke in" since then.
08-04-2020, 06:37 PM | #76 |
Rep 12
Replaced mine last summer. I ended up stripping the stupid torx hole somehow, ended up yanking the pin with pliers and brute force. It was miserable and I have zero clue what I'm going to do next time I need this replaced. Hopefully not any time soon
09-23-2020, 12:39 PM | #78 |
![]() ![]() 4496
Rep 7,753
Let us know how much of a difference it makes for you. Mine looked more or less exactly the same after dealer replaced it under warranty, but ive seen some videos where the "after" looks rock solid.
09-23-2020, 12:47 PM | #79 |
Moto Lover
212
Rep 626
Drives: '19 BMW S1000XR
Will do. I'll try to remember and get a before and after video.
12-12-2020, 09:35 PM | #80 |
![]() 143
Rep 152
Drives: '20 BMW F87 M2C
I just replaced mine a few days ago. The jiggling is noticeably less, but there is still some small level of wiggle. The old belt seemed almost new. I ensured torque specs were correct, so I'm also inclined to think that a small amount of jiggling is normal.
10-05-2021, 02:48 PM | #81 |
Rep 1
Just bought a 2012 335i F30
Hello, I picked this up a few weeks ago and heard a small squeal during LOW RPM's
Video: https://drive.google.com/file/d/1pdK...ew?usp=sharing I'm not sure if I need to change it right away or if I can wait a week so I can be back in montreal (in toronto currently) |
10-05-2021, 05:47 PM | #82 |
![]() ![]() 6338
Rep 5,746
I replaced my 5 y/o tensioner earlier in the year. I can't say it made any real difference in the jiggle. FYI, the tensioner will jiggle quite a bit, even new, when the air conditioner is on. The extra load of the A/C compressor really pulls on the tensioner. It might be why some hardly see any jiggling and others significant jiggling.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
10-06-2021, 12:09 AM | #83 | |
![]() ![]() 4496
Rep 7,753
02-01-2025, 10:51 AM | #84 |
2018 X5 F15 N55
![]() 32
Rep 77
I know this is older but definitely timeless. My tensioner does the same thing, it juggles quite a bit. And doe it’s even making a slight rattling noise as it jiggles. So I know the bearing is going out. Time to change it!
