BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 2013 335i N55 E93 Some Error codes, not quite sure what they mean
proTUNING Freaks
      05-25-2019, 05:45 AM   #1
Bimbobway
Drives: 2013 335i & 2006 328i
2006 BMW 325i  [0.00]
2013 BMW 335i  [0.00]
2013 335i N55 E93 Some Error codes, not quite sure what they mean.
I recently installed a VSRF Down Pipe and inter cooler. Immediately after install, I found these codes and the car went in to reduced power mode. Does any one have any ideas? I know it sounds like pinched or shorted wires. So the first thing I did was break out a meeter and did on Ohm check on the waste-gate control module, and O2 sensors, I found no shorts to ground.
  • EWD DME Interface fault
  • Terminal 87_1 No Voltage,
  • O2 Sensor heating after catalytic activation short circuit to earth
  • Wastegate Shorted to earth
      05-29-2019, 07:44 AM   #2
Bimbobway
So I figured it out, it was simple. I found a blown 20 amp fuse, so my thinking is terminal 87 was missing voltage and it was common to both O2 sensors and the waste gate control. Put a new fuse in and the codes cleared.
Kefka33.50
      11-25-2019, 01:46 PM   #3
fryj00
Drives: 2011 E92 N55 xdrive 6MT
Would you mind detailing the location of that fuse?
Thanks!
-Bryan
2011 E92 N55 xDrive 6MT | VTT Stage 1 | DV+
Stage 2 lpfp | BMS Intake
Shifteck 4" kittyless DP | MXP catback
VRSF 7" FMIC | VRSF Chargepipe
ECS 2-piece rotors and bronze guides
      02-06-2025, 05:59 PM   #4
jorgemedina_04
jorgemedina_04's Avatar
Drives: bmw e92 335i 2012 (N55)
Where was the fuse?
