BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Blue smoke
      07-11-2022, 05:16 PM   #1
Bloom_435i
Bloom_435i's Avatar
Drives: 18' m550i
2018 G30 M550i  [0.00]
Recently my 435i has been blowing blue smoke but only after idling for a little bit then once you go, it smokes. Also there is no smoke while driving.The car drives the same and the car isn't throwing any codes. Tomorrow I'm going to check in the chargepipe to see if theirs oil in it. Just looking for any ideas of what it could be. I'm leaning towards bad valve guide seals because another forum member had also experienced this.
      07-11-2022, 06:02 PM   #2
thejeremyman9
thejeremyman9's Avatar
4495
Drives: 2015 BMW 335i
Oil in inlet/TIC/IC/CP is blowby from CCV hose.
Oil going directly into the combustion chamber is likely valve guide seals as you mentioned
Oil going into DP and burning off in the exhaust can be turbo seals.
Just need to figure out where the oil is
F32Fleet3996.50
      02-05-2025, 01:39 PM   #3
abrar2498
Drives: F30 2015 335i
were you able to pinpoint and resolve this issue? Experiencing something similar w my n55
