BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > P750 Dyno Results:
      10-21-2024, 05:31 PM   #1
AmuroRay
AmuroRay's Avatar
3286
Drives: M235i
P750 Dyno Results:
On the M2 side:
https://f87.bimmerpost.com/forums/sh...010464&page=16
Originally Posted by VGSON View Post
hit a dyno day today..good info but also not so good. New revision from tuner needs some revising..there where throttle closures, timing corrections, etc..Im guessing he was trying something out to fix it not hitting boost target at 5500-6k. Its more responsive down low, but uptop acts a little funny. Still didn’t hit boost target on the dyno that well compared to street…Even with all this it hit 633/625 on a stingy dyno. Hellcat hit about same #’s i did, gt500 with work done hit 700. My car was spinning; so they threw a guy in the trunk. Hopefully the sound comes thru the vids. It sounds great.
...I am truly impressed with what it did today. Especially when you factor in what was going on in the current tune.
Fuel today: E45
Next: Getting the tune refined. I want that 5000-6500rpm torque as flat as possible(smooth). Also working with Steve (wedge) to see if mid 6’s 60-130 is possible. This power level is pretty solid. Its damn reliable as my daily and right on the line where theres tons of power but also have traction.
Eventually; stage’s a/w intercooler & maybe ported head with their cams.
E45 633whp/624wtq
Mods: Yes.
As long 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
      10-21-2024, 09:35 PM   #2
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [9.75]
2009 Honda Civic  [0.00]
I want to pull the trigger on a Pure 750 but I feel like an EFR is a better buy especially when you get into the 600+ range. Now, if they made us a Pure 850, I'd buy that. Maybe I'm wrong in my thinking?
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      10-22-2024, 02:29 PM   #3
LA1Z24
Drives: 2014 435i M Sport
Why did they stop at e45? Not enough fueling with the car? I wanna see a number in the 7s damn it
      10-22-2024, 09:11 PM   #4
Boostedphil698
You're going to be pushing the turbo real hard to get to 700whp.
      10-23-2024, 09:15 AM   #5
AmuroRay
AmuroRay's Avatar
3286
Drives: M235i
You should fight him. VGSON
Mods: Yes.
LA1Z24480.50
VGSON451.50
      10-23-2024, 01:02 PM   #6
VGSON
OG
VGSON's Avatar
Drives: F87 OGM2
if you can afford an efr kit do it. Efficiency will DEFINITELY be better. Doubt they will make an 850/900 since the standard blocks or trans dont last much above 700..One of the guys lifted the head with his 750. Once you’re going built motor/etc…doesn’t make sense to go hybrid.
      10-23-2024, 01:06 PM   #7
Boostedphil698
I saw that InHousePerformance lifted his head. His 535i build is really cool. I plan to do a build motor with a closed deck block. The problem I'm running into is finding an EFR internally gated turbo that will work on my Xdrive car. 4N Motorsport has yet to confirm if their kits fits Xdrive.
      10-23-2024, 01:07 PM   #8
VGSON
OG
VGSON's Avatar
Drives: F87 OGM2
Cause thats what i had in her..Filled it up at the station before heading in…might get a pail of sunoco e85 next time, but im always using pump with a mix around e50…
I doubt we’ll see 7’s out of this turbo. 100% duty cycle on race gas might do it but i’d never run it that way…This setup has 650+ in it easy. You’re welcome to get a pure750, port injection and go for it though
      10-23-2024, 01:10 PM   #9
VGSON
OG
VGSON's Avatar
Drives: F87 OGM2
Boostedphil698
Did you hitup 4N? they seem
to be the only guy i know offering a efr…most go with external..Maybe top mount speedtech with external gates would offer clearance…Go precision or pulsar(?)
      10-23-2024, 01:14 PM   #10
Boostedphil698
Boostedphil698
I'm waiting for them to respond. I have a BPM4 EKP so I have a fuel system that can withstand up to 1200hp so I'd like to take advantage of a full frame turbo when the time is right. Most important to me is packaging and retaining stock like drivability. The turbos I'd consider are BorgWarner, Precision or Garret.
VGSON451.50
      10-23-2024, 02:17 PM   #11
VGSON
OG
VGSON's Avatar
Drives: F87 OGM2
fyi regarding turbo size & speed…steve wedge built a 235 with a bigboost 3.4 kit on pi. did 5.5 60-130..think he was mid 700’s on 36 psi
      10-23-2024, 02:20 PM   #12
Boostedphil698
I did see that. Luckily with my EKP, it's canbus integrated where I can skip PI and do straight DI. I think Big Boost is a great value but would prefer one of the three Turbo manufacturers I listed earlier.
      10-23-2024, 05:04 PM   #13
wheela
wheela's Avatar
597
Drives: 2015 BMW X1 35i M-sport
You could reach out and ask them, I know an e-chassis guy they did a Garret for. And they do EFR for b58 and s55, so they're familiar. Disclaimer, that guy's garret kit didn't exactly fit well, but he did get it running with some mods.
      10-23-2024, 05:06 PM   #14
Boostedphil698
I'll probably go BorgWarner but you have given me another option in asking them.
      02-07-2025, 08:13 AM   #15
AmuroRay
AmuroRay's Avatar
3286
Drives: M235i
Soooo..Got a revision & there’s a dyno near my work..still working on the top end, but need to pull some of that torque down 😆.E58 fuel this time.
https://youtube.com/shorts/E_jN08dUO...GC9EWVSwupVEhY
Updated
Mods: Yes.
VGSON451.50
      02-09-2025, 11:26 AM   #16
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Excellent results but more importantly the power curve looks great, it must a very fun daily driver with the way its building up boost
https://x-ph.com/sale/
Phone number 702-494-9435
      02-12-2025, 06:01 AM   #17
lens
lens's Avatar
2251
Drives: 2018 340i xDrive
It's safer too.
Less torque punch at lower RPMs means less chance of stuff breaking.
